OKC EDACS and Etrunker
KK5FM
Guthrie, OK
I finally got around to programming the OKC trunk system into a scanner, and found that on Sunday evening, they were simulcasting the following:
tg / simulcast with
10-002 / 158.970
10-003 / 159.090
10-004 / 159.030
The other major patrol channel, 159.790, did not appear to be simulcast. This traffic was in analog, on the "inner ring" system. There was an audio delay between the trunk rebroadcast and the parent vhf channel.
Just guessing, but they probably wanted to load the system with real-world traffic, or maybe they too got tired of "testing 1, 2, 3..."
mam1081
Next to a scanner...
Is there anyone with etrunk or Unitrunker that can run it on these systems? Unitrunker is now out (Beta version). You still need to have your scanner's discriminator tapped, but then all you need is a regular audio cable to your soundcard. It will work with Motorola Type I, II and P25, EDACS, and MPT systems. Try it out (available for download in the "Trunker/T4WIN decoders" forum section). You should be able to see the digital talkgroups with this going.
