Mammoth Mtn. Ski Area Went Dead to Me This Morning
es93546
A Member Twice
Right Side of CA on maps
Did you program the LCN for each frequency?
I never programmed the LCN for each frequency. I was hearing audio on the Lincoln Lift site without doing so. I will go back and see if doing so makes a difference. Funny, I was up at about 0400 and wanted to start fresh on new log pages so I deleted all the log entries so I would have a fresh page, given that the opening of ski season on the 15th of November would be starting later that morning. That is the last time I was able to log anything, until I logged (without audio) on the limit search.
Again, I will try the information given me in the links for each site.
es93546
A Member Twice
No, it was logging (with audio) on the Lincoln Lift site without any LCN info. It did not pick up talkgroups or audio on the Mammoth Summit site so somehow it was working on the Lincoln Lift site without it. I have no explanation for that.
es93546
A Member Twice
I rarely use the database as I am running DSDPlus or SDRTrunk or UniTrunker. I only recall the LCN being in small numbers next to the freqs but I just realized that they are under the sites. So here are the LCNs for the 3 sites in the database:
Where does the Channel ID number get entered? My frequency screen only shows (from left to right), Frequency, LCN, Color Code and Lockout. There isn't a Ch ID column.
es93546
A Member Twice
It doesn't look like you have it programmed in as a DMR Trunked system (although nobody would know because you haven't posted screenshots of the actual programming in the scanner). It should be programmed in as DMR/MotoTRBO -> MotoTRBO Trunk.
And for every frequency you add, you need to also add the LCN. If you click on the "Mammoth Mtn Summit" site for instance, you will see any LCN associated with each frequency as well as a color code. You need to program the LCN and color code in for each frequency when you program the frequency in.
I would have no idea how to post screenshots of the actual programming in the scanner, that is why I haven't done so. Much of this is over my head, I'm not much of a techy. Hopefully I'm learning something with all of this, but I won't know until I get the system to work.
es93546
A Member Twice
I'm picking up the snow grooming (snow cats) talkgroups now on both the Mammoth Mountain Summit site and the Lincoln Lift site. I won't be able to make sure I'm picking all the talkgroups I previously recorded (on a piece of lined notebook paper with pencil). I don't know, yet, how to produce audio recordings of what I hear. I have no explanation as to how I was picking up audio and history logging without the LCN and color tone before. It worked for nearly a month, until it didn't. With the ski area being busy during a holiday weekend I should be able to figure out the function of each talkgroup.
One thing I pretty well versed on is the organizational structure of the ski area and how they communicated on the old Type I trunked system. My wife and I have a friend who works at the mountain and I might be able to convince him to get me a printed channel list.
One last question for now. Does a signal transmitted by one site get transmitted on the other two sites in the system? In that way, if someone calls someone using the Lincoln Lift site, does the signal get picked up on the Chair 12 site, for someone who is only in range of the Chair 12 site?
THANK YOU, THANK YOU AND THANK YOU for all of you that have been helping me with this!!!!!! I'm glad they didn't flip the old "E" switch, which was my fear. With my knowledge of how the ski area functions I should be able to start posting some talkgroup info here between now and Christmas.
es93546
A Member Twice
I forgot to mention that the day I stopped hearing the audio and the history log showed no talkgroups was a on the 15th of November and prior to that I was hearing the Lincoln Mtn. site without LCN info being entered. I'm still mystified by what changed early that morning. I wonder if it was something the ski area did or something else. I guess it doesn't really matter if it continues to work now. It was only down for a little less than 2 weeks, thanks to everyone who helped out here.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Without LCNs (and the proper ones) your scanner will not trunktrack. You might be able to cycle through each channel on a site and hear something, or not, but the idea is you want it to actually track conversations. You need to have everything programmed in for each frequency, LCN and Color Code. And, until you know it is working 100%, you should also set, I believe in the System Options for that particular system, ID SEARCH (instead of ID SCAN). ID Search will then play audio for every talkgroup that is active / not encrypted, even if you don't have that specific talkgroup programmed in. After you get it all working you scan switch to ID Scan if you prefer.
officer_415
SF Bay Area
The scanner uses LCN, not Channel ID (each LCN has two Channel IDs or LSNs, so it's redundant info). You just need to program the LCN.
es93546
A Member Twice
Good news! The radio system is firing on all cylinders! I'm starting to figure out a couple of the talkgroups. I will attempt to figure out more before submitting database updates. Maybe by the end of the day. Again, thanks for everyone's patience with me.
es93546
A Member Twice
A thought on that, given it's a time divided system, wouldn't it accommodate two conversations on one frequency? So it's really not redundant, it's to accommodate the two simultaneous conversations.
es93546
A Member Twice
I have the radio on ID Search. I will keep it that way until I figure out every talkgroup. Fortunately, the way the ski area is using this new radio system is pretty much like they were using the old system. They didn't get rid of their callsigns and other procedures just because they replaced the radio system.
es93546
A Member Twice
A portion of what I've logged this A.M.:
History Grid Log
Date Generated: 11/29/24 10:15:08
Scanner Type: BCD325P2
Talk Group ID Frequency Tone RSSI UID Mod. Hits Duration Start Date / Time End Date / Time System / Site Group Channel Number Tag Tune
i0 855.5125 CC 0 338 NFM 1 00:00:05 11/29/24 10:14:41 11/29/24 10:14:46 MMSA Lincoln 2
1009 858.8125 278 NFM 14 00:00:00 11/29/24 10:14:04 11/29/24 10:14:04 MMSA Summit Operations Gondolas 2
1017 857.5125 CC 0 307 NFM 10 00:00:04 11/29/24 10:13:40 11/29/24 10:13:45 MMSA Summit Operations LIft Operations 2
1017 857.5125 312 NFM 9 00:00:00 11/29/24 10:13:40 11/29/24 10:13:40 MMSA Summit Operations LIft Operations 2
1017 857.5125 CC 0 364 NFM 8 00:00:05 11/29/24 10:12:20 11/29/24 10:12:26 MMSA Summit Operations LIft Operations 2
1017 857.5125 363 NFM 7 00:00:00 11/29/24 10:12:20 11/29/24 10:12:20 MMSA Summit Operations LIft Operations 2
889 855.3375 CC 0 312 NFM 2 00:00:12 11/29/24 10:12:04 11/29/24 10:12:16 MMSA Lincoln 2
889 855.3375 338 NFM 1 00:00:00 11/29/24 10:12:03 11/29/24 10:12:03 MMSA Lincoln 2
1031 855.3375 CC 0 311 NFM 4 00:00:04 11/29/24 10:11:53 11/29/24 10:11:58 MMSA Lincoln Operations Sports School 2
1017 857.5125 CC 0 403 NFM 6 00:00:04 11/29/24 10:11:39 11/29/24 10:11:43 MMSA Summit Operations LIft Operations 2
i1033 856.5125 CC 0 305 NFM 1 00:00:02 11/29/24 10:11:27 11/29/24 10:11:30 MMSA Summit 2
1020 858.8125 CC 0 271 NFM 8 00:00:08 11/29/24 10:11:17 11/29/24 10:11:26 MMSA Summit Operations Ski Patrol 2
1035 855.9375 CC 0 327 NFM 2 00:00:06 11/29/24 10:11:05 11/29/24 10:11:12 MMSA Lincoln Operations Woollys Tube/Cst 2
1009 857.5125 CC 0 344 NFM 13 00:00:10 11/29/24 10:10:43 11/29/24 10:10:53 MMSA Summit Operations Gondolas 2
1009 857.5125 357 NFM 12 00:00:00 11/29/24 10:10:43 11/29/24 10:10:43 MMSA Summit Operations Gondolas 2
1020 855.8375 CC 0 354 NFM 7 00:00:14 11/29/24 10:08:51 11/29/24 10:09:06 MMSA Summit Operations Ski Patrol 2
1020 855.8375 353 NFM 6 00:00:00 11/29/24 10:08:51 11/29/24 10:08:51 MMSA Summit Operations Ski Patrol 2
1031 855.8375 CC 0 347 NFM 4 00:00:15 11/29/24 10:08:32 11/29/24 10:08:47 MMSA Summit Operations Sports School 2
1015 858.8125 CC 0 254 NFM 7 00:00:03 11/29/24 10:08:23 11/29/24 10:08:27 MMSA Summit Operations Lift Maintenan 1 2
1015 858.8125 CC 0 266 NFM 6 00:00:10 11/29/24 10:08:10 11/29/24 10:08:21 MMSA Summit Operations Lift Maintenan 1 2
1015 858.8125 262 NFM 5 00:00:01 11/29/24 10:08:09 11/29/24 10:08:10 MMSA Summit Operations Lift Maintenan 1 2
1015 858.8125 CC 0 245 NFM 4 00:00:04 11/29/24 10:08:04 11/29/24 10:08:09 MMSA Summit Operations Lift Maintenan 1 2
1026 855.8375 CC 0 354 NFM 1 00:00:13 11/29/24 10:06:14 11/29/24 10:06:27 MMSA Summit Operations 1026 2
1009 858.8125 CC 0 308 NFM 11 00:00:18 11/29/24 10:05:51 11/29/24 10:06:09 MMSA Summit Operations Gondolas 2
1009 857.5125 CC 0 359 NFM 10 00:00:19 11/29/24 10:05:22 11/29/24 10:05:42 MMSA Summit Operations Gondolas 2
1035 855.1625 CC 0 186 NFM 1 00:00:13 11/29/24 10:03:53 11/29/24 10:04:07 MMSA Lincoln Operations Woollys Tube/Cst 2
1006 857.5125 CC 0 330 NFM 7 00:00:03 11/29/24 10:03:43 11/29/24 10:03:46 MMSA Summit Operations Building Mainten 2
1010 856.5125 CC 0 414 NFM 8 00:00:04 11/29/24 10:03:19 11/29/24 10:03:23 MMSA Summit Operations Hosts 2
1010 856.5125 CC 0 376 NFM 7 00:00:04 11/29/24 10:03:13 11/29/24 10:03:17 MMSA Summit Operations Hosts 2
1010 856.5125 382 NFM 6 00:00:00 11/29/24 10:03:13 11/29/24 10:03:13 MMSA Summit Operations Hosts 2
1019 855.8375 CC 0 424 NFM 9 00:00:07 11/29/24 10:03:01 11/29/24 10:03:09 MMSA Summit Operations Buses 2
1009 858.5125 CC 0 379 NFM 9 00:00:04 11/29/24 10:02:52 11/29/24 10:02:57 MMSA Summit Operations Gondolas 2
1009 855.8375 CC 0 402 NFM 8 00:00:04 11/29/24 10:02:47 11/29/24 10:02:51 MMSA Summit Operations Gondolas 2
1031 855.5125 CC 0 343 NFM 3 00:00:16 11/29/24 10:02:22 11/29/24 10:02:38 MMSA Lincoln Operations Sports School 2
1031 855.5125 348 NFM 2 00:00:00 11/29/24 10:02:22 11/29/24 10:02:22 MMSA Lincoln Operations Sports School 2
1035 858.8125 CC 0 349 NFM 2 00:00:04 11/29/24 10:01:55 11/29/24 10:02:00 MMSA Summit Operations Woollys Tube/Cst 2
1031 858.5125 CC 0 370 NFM 3 00:00:05 11/29/24 10:01:26 11/29/24 10:01:32 MMSA Summit Operations Sports School 2
1009 856.5125 CC 0 345 NFM 7 00:00:18 11/29/24 10:00:53 11/29/24 10:01:12 MMSA Summit Operations Gondolas 2
1020 858.5125 CC 0 382 NFM 5 00:00:02 11/29/24 10:00:44 11/29/24 10:00:46 MMSA Summit Operations Ski Patrol 2
1020 858.5125 372 NFM 4 00:00:00 11/29/24 10:00:44 11/29/24 10:00:44 MMSA Summit Operations Ski Patrol 2
1006 858.5125 CC 0 370 NFM 6 00:00:10 11/29/24 10:00:29 11/29/24 10:00:40 MMSA Summit Operations Building Mainten 2
1006 858.5125 376 NFM 5 00:00:00 11/29/24 10:00:29 11/29/24 10:00:29 MMSA Summit Operations Building Mainten 2
1006 856.5125 CC 0 141 NFM 4 00:00:15 11/29/24 10:00:13 11/29/24 10:00:29 MMSA Summit Operations Building Mainten 2
1006 856.5125 354 NFM 3 00:00:00 11/29/24 10:00:13 11/29/24 10:00:13 MMSA Summit Operations Building Mainten 2
1009 855.8375 CC 0 406 NFM 6 00:00:06 11/29/24 09:59:57 11/29/24 10:00:03 MMSA Summit Operations Gondolas 2
1009 858.8125 360 NFM 4 00:00:00 11/29/24 09:59:55 11/29/24 09:59:55 MMSA Summit Operations Gondolas 2
1022 856.5125 CC 0 358 NFM 6 00:00:54 11/29/24 09:58:57 11/29/24 09:59:51 MMSA Summit Operations 1022 2
1022 855.8375 CC 0 400 NFM 5 00:00:39 11/29/24 09:58:16 11/29/24 09:58:55 MMSA Summit Operations 1022 2
1033 855.8375 CC 0 400 NFM 1 00:00:10 11/29/24 09:58:01 11/29/24 09:58:12 MMSA Summit Operations 1033 2
1022 858.5125 CC 0 368 NFM 4 00:00:22 11/29/24 09:57:33 11/29/24 09:57:55 MMSA Summit Operations 1022 2
1009 858.5125 372 NFM 2 00:00:00 11/29/24 09:57:23 11/29/24 09:57:23 MMSA Summit Operations Gondolas 2
1022 855.7625 CC 0 356 NFM 5 00:00:25 11/29/24 09:56:54 11/29/24 09:57:20 MMSA Lincoln Operations 1022 2
1022 855.7625 356 NFM 4 00:00:00 11/29/24 09:56:54 11/29/24 09:56:54 MMSA Lincoln Operations 1022 2
1010 855.8375 CC 0 394 NFM 5 00:00:10 11/29/24 09:56:31 11/29/24 09:56:42 MMSA Summit Operations Hosts 2
1015 858.5125 CC 0 358 NFM 2 00:00:12 11/29/24 09:56:14 11/29/24 09:56:27 MMSA Summit Operations Lift Maintenan 1 2
1019 856.5125 CC 0 357 NFM 8 00:00:43 11/29/24 09:55:26 11/29/24 09:56:10 MMSA Summit Operations Buses 2
1019 856.5125 359 NFM 7 00:00:00 11/29/24 09:55:26 11/29/24 09:55:26 MMSA Summit Operations Buses 2
1022 855.8375 CC 0 411 NFM 3 00:00:21 11/29/24 09:54:42 11/29/24 09:55:03 MMSA Summit Operations 1022 2
1022 855.5125 CC 0 334 NFM 3 00:00:10 11/29/24 09:54:28 11/29/24 09:54:39 MMSA Lincoln Operations 1022 2
1022 855.5125 341 NFM 2 00:00:00 11/29/24 09:54:28 11/29/24 09:54:28 MMSA Lincoln Operations 1022 2
i1031 858.5125 CC 0 375 NFM 3 00:00:02 11/29/24 09:54:21 11/29/24 09:54:24 MMSA Summit 2
i1031 858.5125 388 NFM 2 00:00:00 11/29/24 09:54:21 11/29/24 09:54:21 MMSA Summit 2
1006 856.5125 CC 0 366 NFM 2 00:00:32 11/29/24 09:53:46 11/29/24 09:54:19 MMSA Summit Operations Building Mainten 2
1006 858.8125 CC 0 376 NFM 1 00:00:04 11/29/24 09:53:32 11/29/24 09:53:36 MMSA Summit Operations Building Mainten 2
1017 857.5125 CC 0 409 NFM 4 00:00:12 11/29/24 09:53:15 11/29/24 09:53:28 MMSA Summit Operations LIft Operations 2
1017 857.5125 416 NFM 3 00:00:00 11/29/24 09:53:15 11/29/24 09:53:15 MMSA Summit Operations LIft Operations 2
1020 856.5125 CC 0 365 NFM 2 00:00:14 11/29/24 09:52:56 11/29/24 09:53:11 MMSA Summit Operations Ski Patrol 2
1015 856.5125 CC 0 329 NFM 1 00:00:24 11/29/24 09:52:28 11/29/24 09:52:52 MMSA Summit Operations Lift Maintenan 1 2
1019 855.8375 CC 0 377 NFM 6 00:00:16 11/29/24 09:52:07 11/29/24 09:52:24 MMSA Summit Operations Buses 2
1019 855.8375 377 NFM 5 00:00:00 11/29/24 09:52:07 11/29/24 09:52:07 MMSA Summit Operations Buses 2
1031 855.5125 CC 0 339 NFM 1 00:00:11 11/29/24 09:51:52 11/29/24 09:52:03 MMSA Lincoln Operations Sports School 2
1024 858.5125 CC 0 359 NFM 2 00:00:10 11/29/24 09:51:37 11/29/24 09:51:47 MMSA Summit Operations
Does anyone know what is signified by the "i" in front of a couple of the talkgroup numbers?
es93546
A Member Twice
With the outstanding performance of my scanner on this radio system, I can now retitle this thread as "Mammoth Mtn. Ski Area Came Alive to Me This Morning." For many of you who are 1,000 times the techy I am, this might not seem to be a big deal, but it is to me. It will take me some time to figure out the functions of all the talkgroups and to submit the appropriate database updates, but rest assured that I will be doing that.
mtindor
OH/WV DB Admin
History Grid Log
An "i" I believe indicates a private call (radio to radio) -- not through a talkgroup.
mtindor
OH/WV DB Admin
Sounds like you are having a blast with it now. Glad to hear that. And I've had these types of Uniden scanners since they've come out, and I still can't deal with programming them. I know how to program them, but it isn't a pleasant experience and did take me some time to learn. I've got an SDS100 that I've programmed only since I bought it, 6.5 years ago. That's how much I loath programming it.
Have fun!
officer_415
SF Bay Area
Redundant information for programming purposes. If the scanner has the LCN, it knows the LSNs.
cg
Connecticut
With the 325P2, the only way to record with ProScan is by plugging a jumper from the external speaker jack to the microphone in of the computer. You then need to be sure the mic is the default or else match up the ProScan setting with the mic input setting.
mtindor
OH/WV DB Admin
What is "LSN."
LCN = Logical Channel number - tied to a frequency
LSN = Logical Slot Number - tied to a timeslot (pretty specific to DMR, since DMR is TDMA, two timeslots, two voicepaths)
You only need to pay attention to "LCN" in the DB for DMR if you are programming a scanner. Don't pay attention to LSN.
You only need to pay attention to LSN in the DB if you are using the DB to set up DSDPlus.
