Mammoth Mtn. Ski Area Went Dead to Me This Morning
es93546
A Member Twice
Right Side of CA on maps
I put in the additional frequencies and the system is still silent. I can't get the radio to scan the other systems. I use the keypad to scan the conventional systems in the radio and nothing happens. Also, and this might be the key to this mystery, I fully take the radio to zero squelch and don't hear a data stream. So it would seem that the frequencies have been changed. I'm going to get out my PSR-500 or try on my external PSR-600 and start doing some conventional searching to find a data channel(s). I want this thing to work on the Mountain's system by Thanksgiving as I will be able to figure out talkgroups easier when the system is busy.
cg
Connecticut
You also mentioned you are not picking up "the other systems". Do you mean the other sites or is the scanner not working on other local systems?
Also, are you fairly close to the site locations? It is possible if they did work that they have changed the signal strength. Or perhaps added encryption although I can't imagine what a ski area would need to hide.
Last suggestion I would have is to put all the frequencies in a conventional system and try scanning them that way.
Really need for someone to run DSDPlus on a control channel to determine the system unknowns.
Good luck.
officer_415
SF Bay Area
I see all bars show up for each site (3 of them) and this is presumably the control channel at each site. I did not receive two out of the three sites, just the Lincoln Mtn. site.
This really sounds like a setting has been changed on the scanner, versus something changing about the system. Is it still programmed as a DMR trunked system?
es93546
A Member Twice
Good luck.
1. I could not get the 325P to scan the other the other numerous systems I have programmed into it. There are about 25-30 of them. I finally reprogrammed the entire radio, the entire memory. I can now bring up the other systems in the entire radio and have the radio scan them. I'm not sure what happened, but thought I should start from from square one. It took a long time to reload the entire radio, but it worked. I was able to have the radio scan a conventional system I have programmed into the first bank. It is receiving quite nicely.
2. I'm no more than 5-8 miles from two of the sites, Lincoln Chair and Mammoth Mtn. Summit.
3. I ran a limit search on everything from 855 to 860 on my GRE PSR-600 in a conventional search. I picked up trunking data channels on the two listed in the database. These two frequencies ran a data stream without interruption. I picked up what sounds like a data stream on all the other channels except the highest frequencies listed for the Summit Site and Lincoln Lift Site. These other frequencies transmitted data about as long as a single radio conversation would last. The Chair 12 site is around the other side of the mountain from me and not high enough for me to receive it.
4. I've had my radio scanning now for about 1 hour with no traffic received. Typically not much is heard at this time of night (2245) so nothing definitive yet. I will run the scanner and logger all night long and tomorrow as well.
5. One of my first thoughts was encryption was added on the first day of this ski season. I sure hope not. I've always enjoyed listening to this ski area as I like to know what the employees are up against in their daily duties. Can a system like this ski area's be encrypted?
6. I have no idea what a "DSDPlus' is or means.
Thanks for trying to help.
P.S. I still have the Southern California Edison system to listen to on this radio in case this Mammoth Mtn. system doesn't work out.
es93546
A Member Twice
The database shows TRBO. That is what it has been since I programmed it. Is this correct?
Thanks to everyone for replying to me in an effort to help. I appreciate it more than you realize!
cg
Connecticut
Trbo is correct for the system as it appears in the RR database.
There is an option in the custom search for Control Channel Only. Turn that on and repeat the search. When it gets to one of the known Control Channels, hit Hold. After a couple seconds, it should show the System ID and Site ID. You may see the scanner trying to change frequencies. If the system allows it, it may tune to traffic.
There is another possible way with Proscan to log the data from the control channel. With that, maybe we can see if there is a LCN to program in.
With the system scanning a single site, you would simply go to the CC-Output tab and choose Log to Box and Log to File. Then click start. Data should stream down the box. After a minute or so, click stop. Post the file.
es93546
A Member Twice
I understood everything and followed the procedure as you outlined, with one exception. What do you mean by "Post the file?" Does that mean post it on a thread post here? There is a ton of data and I don't know what to do with it.
es93546
A Member Twice
I'm beginning to lean toward a logical channel situation here. I put the channels for each site into my 325P2 from the start of monitoring this system. I was not surprised that the radio did not track the Chair 12 site. As I mentioned before topography would prevent me from hearing it. My frequency search had no hits on any of this site's frequencies. However, it had hits on both the Mammoth Summit and Lincoln Lift sites. My radio never tracked the Mammoth Summit site. I assumed, prior to doing the frequency search, that I was not receiving any of the Summit site frequencies, but that was not true. Why was it not tracking? I assume that the frequency, lowest to highest as listed in the database, is not the correct order or LCN. How is this voluminous file of recording I just did for the Lincoln Lift site going to help me figure out the LCN?
For unknown reasons the LCN must have been changed for the Lincoln Lift site the day of the season opener. Once I figure out this site I would like to do the same for the Mammoth Summit site as well.
es93546
A Member Twice
Ok, if this works I'm posting 58 seconds of the log.
11/25/24 13:01:00,DMR,E8803206B2408380006A
11/25/24 13:01:00,DMR,02408A00
11/25/24 13:01:00,DMR,99100900F64089000000
11/25/24 13:01:00,DMR,99000900F6408B000000
11/25/24 13:01:00,DMR,99904902F24089000000
11/25/24 13:01:01,DMR,99100900F64089000000
11/25/24 13:01:01,DMR,A11007948003F5000403
11/25/24 13:01:01,DMR,98D08900F64081040020
11/25/24 13:01:01,DMR,99F00902E64089000000
11/25/24 13:01:01,DMR,B11007900003F700040B
11/25/24 13:01:01,DMR,99908902F60081140020
11/25/24 13:01:01,DMR,02408A009C0131D80000
11/25/24 13:01:01,DMR,99841800F60093110020
11/25/24 13:01:01,DMR,99B40902E64081040020
11/25/24 13:01:01,DMR,F208273003F100000000
11/25/24 13:01:01,DMR,02408A009C0132C70000
11/25/24 13:01:04,DMR,99900900F64095000000
11/25/24 13:01:04,DMR,9D100902E24095000000
11/25/24 13:01:04,DMR,02409600240132C70000
11/25/24 13:01:04,DMR,A8803200424097C00045
11/25/24 13:01:04,DMR,99901802E6019D000000
11/25/24 13:01:04,DMR,9800190226409F010040
11/25/24 13:01:04,DMR,99911802A60085000000
11/25/24 13:01:04,DMR,02409604340000A90000
11/25/24 13:01:04,DMR,A210018003A109020000
11/25/24 13:01:04,DMR,99801802E6409D000020
11/25/24 13:01:04,DMR,B55206D60803F700040B
11/25/24 13:01:04,DMR,99880902E24095000000
11/25/24 13:01:04,DMR,A004488003F1A0871080
11/25/24 13:01:04,DMR,9FBC1902E700BD000020
11/25/24 13:01:06,DMR,99800902E62099000020
11/25/24 13:01:11,DMR,A110169000000000040B
11/25/24 13:01:11,DMR,98910900F60085000000
11/25/24 13:01:11,DMR,02409600
11/25/24 13:01:11,DMR,99100900F64095000000
11/25/24 13:01:11,DMR,99941802E24095000000
11/25/24 13:01:11,DMR,99000900F64097000000
11/25/24 13:01:11,DMR,98900902A6008D800022
11/25/24 13:01:11,DMR,A090169800404000040B
11/25/24 13:01:11,DMR,A190129010000000042B
11/25/24 13:01:11,DMR,99800902B6409C000020
11/25/24 13:01:11,DMR,A090069000404840042A
11/25/24 13:01:11,DMR,99904902E6409D000020
11/25/24 13:01:11,DMR,A880620256409BC00075
11/25/24 13:01:11,DMR,99911800F61099000030
11/25/24 13:01:12,DMR,99900900F64095000000
11/25/24 13:01:12,DMR,A110169000000000040B
11/25/24 13:01:12,DMR,99900903F64095000020
11/25/24 13:01:12,DMR,02409600
11/25/24 13:01:12,DMR,00110000140080000000
11/25/24 13:01:12,DMR,888A1802026000010020
11/25/24 13:01:12,DMR,99980900F6409D100020
11/25/24 13:01:12,DMR,99800902F6109D000000
11/25/24 13:01:12,DMR,D9900902E64095000000
11/25/24 13:01:12,DMR,02019600350131D70000
11/25/24 13:01:12,DMR,9CA0100C001F82FEFEEA
11/25/24 13:01:12,DMR,9D910900F600BD000020
11/25/24 13:01:12,DMR,A010069000000800042B
11/25/24 13:01:13,DMR,99811802E6419D000028
11/25/24 13:01:13,DMR,02809600350000280000
11/25/24 13:01:13,DMR,8880720646008FB00065
11/25/24 13:01:13,DMR,98980902E20089000030
11/25/24 13:01:13,DMR,99001900F6409B000010
11/25/24 13:01:13,DMR,99901820F64095000020
11/25/24 13:01:13,DMR,02409600
11/25/24 13:01:13,DMR,A190169000000840042A
11/25/24 13:01:13,DMR,9D904900F64099200030
11/25/24 13:01:13,DMR,8010169000000000040B
11/25/24 13:01:13,DMR,99100902E6109D100020
11/25/24 13:01:13,DMR,A110169000000000040B
11/25/24 13:01:13,DMR,98100902B64099100030
11/25/24 13:01:13,DMR,A190169000404800042B
11/25/24 13:01:24,DMR,99801802E6409D000020
11/25/24 13:01:24,DMR,A1101830000008000429
11/25/24 13:01:24,DMR,99904900F60085000000
11/25/24 13:01:24,DMR,02409600340131D70000
11/25/24 13:01:24,DMR,A010169000000800042B
11/25/24 13:01:24,DMR,54751105DC595354155C
11/25/24 13:01:24,DMR,57D5C551D1360D444573
11/25/24 13:01:24,DMR,41C11002104409000827
11/25/24 13:01:24,DMR,08080048001000000008
11/25/24 13:01:25,DMR,A13288339813D7000409
11/25/24 13:01:25,DMR,A190169000000A000423
11/25/24 13:01:25,DMR,A01000128043D7000409
11/25/24 13:01:25,DMR,99100903F200B5000020
11/25/24 13:01:25,DMR,A0D0069202000000040B
11/25/24 13:01:25,DMR,99101800F6409D040020
11/25/24 13:01:25,DMR,02409600
11/25/24 13:01:25,DMR,99911800F6409C000024
11/25/24 13:01:25,DMR,9900190AF6C197000020
11/25/24 13:01:25,DMR,99800902E6109D000020
11/25/24 13:01:25,DMR,0240142005019B3E0000
11/25/24 13:01:25,DMR,B08108020042EE080409
11/25/24 13:01:25,DMR,A1D0169010000801042B
11/25/24 13:01:25,DMR,98905802F60199000030
11/25/24 13:01:25,DMR,02409600340131D70000
11/25/24 13:01:25,DMR,A0D988128042A7210428
11/25/24 13:01:26,DMR,A0B09E18024408A1002A
11/25/24 13:01:26,DMR,0240960005019B3E0000
11/25/24 13:01:48,DMR,99100900F64095000000
11/25/24 13:01:49,DMR,99100900F64095000000
11/25/24 13:01:49,DMR,02409600
11/25/24 13:01:49,DMR,A1100C9210405800042C
11/25/24 13:01:49,DMR,99910900F6008D000000
11/25/24 13:01:49,DMR,A1100C9000000000040C
11/25/24 13:01:49,DMR,A8003600760097C0000B
11/25/24 13:01:49,DMR,9C801800F64085000000
11/25/24 13:01:49,DMR,99000902F20087010220
11/25/24 13:01:49,DMR,DD800902F24095000000
11/25/24 13:01:49,DMR,A190189220000823002C
11/25/24 13:01:49,DMR,19110900F64884000004
11/25/24 13:01:49,DMR,0240848035019B3E0000
11/25/24 13:01:49,DMR,9D905802B20185010220
11/25/24 13:01:49,DMR,A1101C9210440000040C
11/25/24 13:01:49,DMR,99009800F64095000021
11/25/24 13:01:49,DMR,00101420340131D70000
11/25/24 13:01:49,DMR,99901802F200C5000020
11/25/24 13:01:49,DMR,98001802F45017010040
11/25/24 13:01:49,DMR,99101802A60085000000
11/25/24 13:01:49,DMR,A1801C9000440000040C
11/25/24 13:01:49,DMR,9D108810B400D1000010
11/25/24 13:01:49,DMR,A0960C9220480000040C
11/25/24 13:01:49,DMR,A1841C9A02500800042C
11/25/24 13:01:49,DMR,98100901E64083100008
11/25/24 13:01:49,DMR,A800320C464092C00051
11/25/24 13:01:49,DMR,9D905822A64098212030
11/25/24 13:01:50,DMR,99114900C64095000000
11/25/24 13:01:50,DMR,0240960034019B3E0000
11/25/24 13:01:50,DMR,A090189000000000040C
11/25/24 13:01:50,DMR,99940902E600B5000000
11/25/24 13:01:50,DMR,9990E902E2409D030800
11/25/24 13:01:50,DMR,02409200350131D70000
11/25/24 13:01:50,DMR,A190189210600000040C
11/25/24 13:01:50,DMR,99941922E64095000020
11/25/24 13:01:50,DMR,A094189000000000040C
11/25/24 13:01:50,DMR,A8C0321436001F80000B
11/25/24 13:01:50,DMR,9D101800F6409D000020
11/25/24 13:01:50,DMR,19240D24755495080000
11/25/24 13:01:50,DMR,55D54555D57FFD545575
11/25/24 13:01:50,DMR,158455511C141C440070
11/25/24 13:01:50,DMR,00000200500041800006
11/25/24 13:01:50,DMR,00C00C892000002400A3
11/25/24 13:01:52,DMR,9991C900F6008D000020
11/25/24 13:01:52,DMR,A0801C9A400008000428
11/25/24 13:01:52,DMR,B8121E40764187C0000B
11/25/24 13:01:52,DMR,99901800F6019D012020
11/25/24 13:01:52,DMR,02409600
11/25/24 13:01:52,DMR,99001802F2109B050230
11/25/24 13:01:52,DMR,99100902A6409D100020
11/25/24 13:01:52,DMR,A1101C9210404802042C
11/25/24 13:01:52,DMR,98101922E6209D000020
11/25/24 13:01:52,DMR,024096003C00003D0000
11/25/24 13:01:52,DMR,99B01822E600DD000020
11/25/24 13:01:52,DMR,B038089485B143000424
11/25/24 13:01:52,DMR,55D54555D57FFD545575
11/25/24 13:01:52,DMR,75C4405350550C421061
11/25/24 13:01:52,DMR,00400824002204E00010
11/25/24 13:01:53,DMR,99100900F64095000000
11/25/24 13:01:53,DMR,02409600
11/25/24 13:01:53,DMR,A1100C9000000000040C
11/25/24 13:01:53,DMR,A800320496409780006D
11/25/24 13:01:54,DMR,99000900F64097000000
11/25/24 13:01:54,DMR,99100900F64095000000
11/25/24 13:01:54,DMR,A1100C9000000000040C
11/25/24 13:01:54,DMR,02409600
11/25/24 13:01:54,DMR,A8003204564097C00045
11/25/24 13:01:56,DMR,99918B00D641B1010000
11/25/24 13:01:56,DMR,99100900F64095000000
11/25/24 13:01:56,DMR,0440960835019B3E0000
11/25/24 13:01:56,DMR,A1100C90000409000000
11/25/24 13:01:56,DMR,02409600
11/25/24 13:01:56,DMR,A8003204764097C0000B
11/25/24 13:01:56,DMR,99000900F64097000000
11/25/24 13:01:57,DMR,A1100C90000409000000
11/25/24 13:01:57,DMR,99100900F64095000000
11/25/24 13:01:57,DMR,02409600
11/25/24 13:01:57,DMR,99000900F64097000000
11/25/24 13:01:57,DMR,02000000938002040000
11/25/24 13:01:58,DMR,99100900F64095000000
11/25/24 13:01:58,DMR,A1100C90000409000000
11/25/24 13:01:58,DMR,02409600
11/25/24 13:01:58,DMR,A800320496409780006D
11/25/24 13:01:58,DMR,99000900F64097000000
cg
Connecticut
It has been a while since I dug into that data but I believe it is not seeing Tier III data. You should be seeing data like this:
07/31/24 14:26:34,DMR,02B00E5F,DT3,NET-0001 SIT-0003
That is the control channel
I just can't remember if it shows that info if programmed as a system or in a search
Try a custom search range with the Control Channel Only turned on:
Menu
Search for...
Edit Custom
(pick one, Custom 1 works if you don't use them)
Edit Search Limit
854.0000 (enter)
860.0000 (enter)
Set Control Ch Only (On)
hit Menu several times to back out to Edit Custom
go up one to Custom Search (enter)
The 10 Custom Searches have 10 Quick Keys (1-0) while you are in the Searching. If you hit scan, you have to go back into the menu. Hit Hold when the search finds a signal, give it a few seconds to show a System ID, Site ID, and DCC
es93546
A Member Twice
I think I followed your instructions. However when I get to the point when I hit hold on a signal, where is it shown the System ID, Site ID and DCC? Where is this supposed to show? I ask because nothing shows, not on the scanners display screen and not on the C-CH Output tab. I presume this tab is where it should show. Also I don't know what "DCC" means.
cg
Connecticut
DCC is digital color code
It would display right on the screen, it alternates with this and another window. 325P2 shows the same as this 996P2
cg
Connecticut
This it to try to ID what you are monitoring. A monitorable signal will give some indication as to what is being heard. Even if encrypted, it should give the color code and system ID.
Digital Color Code (DCC or CC) is the DMR equal of a PL or DPL or NAC (P25) or RAN (NXDN). It allows multiple users in range of one another
to not hear each other.
Net is the Network ID, S is the Site. and what is not seen in the alternating screen says DT3 or DMR Tier3.
Looking to confirm system type, System ID, and Site number. You are not seeing what should be
Also, I missed setting an important option in the menu for the search. When setting it up, be sure you are in the digital tone code search:
Menu
Srch/Close Call Options
Tone/Code Search
NAC/CC/RAN/Area
Enter
es93546
A Member Twice
This is part of what I've recorded this afternoon. No audio was received.
Talk Group, Frequency, Tone, RSSI, UID, Mod, Hits, Duration, Start Date / Time, End Date / Time, System / Site, Group, Channel
1015, 854.8625, , 337, , NFM, 48, 00:00:01, 11/27/24 14:10:07, 11/27/24 14:10:09, Custom 1, Net0001: S0002,
1015, 854.9375, CC 0, 264, , NFM, 47, 00:00:02, 11/27/24 14:08:12, 11/27/24 14:08:15, Custom 1, Net0001: S0005,
1015, 854.9375, , 326, , NFM, 46, 00:00:00, 11/27/24 14:08:12, 11/27/24 14:08:12, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 357, , NFM, 45, 00:00:02, 11/27/24 14:08:09, 11/27/24 14:08:11, Custom 1, Net0001: S0005,
1015, 854.9375, , 370, , NFM, 44, 00:00:00, 11/27/24 14:08:08, 11/27/24 14:08:08, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 330, , NFM, 43, 00:00:02, 11/27/24 14:08:05, 11/27/24 14:08:07, Custom 1, Net0001: S0005,
1015, 854.9375, , 360, , NFM, 42, 00:00:00, 11/27/24 14:08:04, 11/27/24 14:08:04, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 357, , NFM, 41, 00:00:02, 11/27/24 14:08:01, 11/27/24 14:08:04, Custom 1, Net0001: S0005,
1015, 854.9375, , 361, , NFM, 40, 00:00:00, 11/27/24 14:08:01, 11/27/24 14:08:01, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 366, , NFM, 39, 00:00:02, 11/27/24 14:07:57, 11/27/24 14:08:00, Custom 1, Net0001: S0005,
1015, 854.9375, , 366, , NFM, 38, 00:00:00, 11/27/24 14:07:57, 11/27/24 14:07:57, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 369, , NFM, 37, 00:00:02, 11/27/24 14:07:54, 11/27/24 14:07:56, Custom 1, Net0001: S0005,
1015, 854.9375, , 357, , NFM, 36, 00:00:00, 11/27/24 14:07:53, 11/27/24 14:07:54, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 355, , NFM, 35, 00:00:02, 11/27/24 14:07:50, 11/27/24 14:07:53, Custom 1, Net0001: S0005,
1015, 854.9375, , 371, , NFM, 34, 00:00:00, 11/27/24 14:07:50, 11/27/24 14:07:50, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 368, , NFM, 33, 00:00:02, 11/27/24 14:07:47, 11/27/24 14:07:49, Custom 1, Net0001: S0005,
1015, 854.9375, , 372, , NFM, 32, 00:00:00, 11/27/24 14:07:46, 11/27/24 14:07:46, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 365, , NFM, 31, 00:00:02, 11/27/24 14:07:43, 11/27/24 14:07:46, Custom 1, Net0001: S0005,
1015, 854.9375, , 367, , NFM, 30, 00:00:00, 11/27/24 14:07:43, 11/27/24 14:07:43, Custom 1, Net0001: S0005,
1022, 854.9375, CC 0, 372, , NFM, 2, 00:00:02, 11/27/24 14:07:40, 11/27/24 14:07:42, Custom 1, Net0001: S0005,
1022, 854.9375, , 377, , NFM, 1, 00:00:00, 11/27/24 14:07:39, 11/27/24 14:07:39, Custom 1, Net0001: S0005,
1015, 854.9375, CC 0, 368, , NFM, 29, 00:00:02, 11/27/24 14:07:36, 11/27/24 14:07:39, Custom 1, Net0001: S0005,
1015, 854.9375, , 368, , NFM, 28, 00:00:00, 11/27/24 14:07:36, 11/27/24 14:07:36, Custom 1, Net0001: S0005,
1009, 854.9375, CC 0, 369, , NFM, 77, 00:00:02, 11/27/24 14:07:32, 11/27/24 14:07:35, Custom 1, Net0001: S0005,
1009, 854.9375, , 371, , NFM, 76, 00:00:00, 11/27/24 14:07:32, 11/27/24 14:07:32, Custom 1, Net0001: S0005,
1009, 854.9375, CC 0, 368, , NFM, 75, 00:00:02, 11/27/24 14:07:29, 11/27/24 14:07:32, Custom 1, Net0001: S0005,
1009, 854.9375, , 372, , NFM, 74, 00:00:00, 11/27/24 14:07:29, 11/27/24 14:07:29, Custom 1, Net0001: S0005,
1009, 854.9375, CC 0, 353, , NFM, 73, 00:00:02, 11/27/24 14:07:25, 11/27/24 14:07:28, Custom 1, Net0001: S0005,
1009, 854.9375, , 359, , NFM, 72, 00:00:00, 11/27/24 14:07:25, 11/27/24 14:07:25, Custom 1, Net0001: S0005,
1009, 854.9375, CC 0, 369, , NFM, 71, 00:00:02, 11/27/24 14:07:22, 11/27/24 14:07:25, Custom 1, Net0001: S0005,
1009, 854.9375, , 359, , NFM, 70, 00:00:00, 11/27/24 14:07:22, 11/27/24 14:07:22, Custom 1, Net0001: S0005,
1009, 854.9375, CC 0, 360, , NFM, 69, 00:00:02, 11/27/24 14:07:17, 11/27/24 14:07:20, Custom 1, Net0001: S0005,
1009, 854.9375, , 371, , NFM, 68, 00:00:00, 11/27/24 14:07:17, 11/27/24 14:07:17, Custom 1, Net0001: S0005,
1009, 854.9375, CC 0, 351, , NFM, 67, 00:00:02, 11/27/24 14:07:14, 11/27/24 14:07:16, Custom 1, Net0001: S0005,
1009, 854.9375, , 363, , NFM, 66, 00:00:00, 11/27/24 14:07:13, 11/27/24 14:07:13, Custom 1, Net0001: S0005,
1033, 854.9375, CC 0, 342, , NFM, 8, 00:00:02, 11/27/24 14:07:10, 11/27/24 14:07:13, Custom 1, Net0001: S0005,
1033, 854.9375, , 366, , NFM, 7, 00:00:00, 11/27/24 14:07:09, 11/27/24 14:07:10, Custom 1, Net0001: S0005,
1036, 854.9375, CC 0, 340, , NFM, 4, 00:00:02, 11/27/24 14:06:55, 11/27/24 14:06:58, Custom 1, Net0001: S0005,
1036, 854.9375, , 356, , NFM, 3, 00:00:00, 11/27/24 14:06:55, 11/27/24 14:06:55, Custom 1, Net0001: S0005,
1011, 854.9375, CC 0, 363, , NFM, 2, 00:00:02, 11/27/24 14:06:51, 11/27/24 14:06:53, Custom 1, Net0001: S0005,
1011, 854.9375, , 368, , NFM, 1, 00:00:00, 11/27/24 14:06:50, 11/27/24 14:06:51, Custom 1, Net0001: S0005,
6002, 854.9375, CC 0, 365, , NFM, 8, 00:00:02, 11/27/24 14:06:47, 11/27/24 14:06:50, Custom 1, Net0001: S0005,
6002, 854.9375, , 360, , NFM, 7, 00:00:00, 11/27/24 14:06:47, 11/27/24 14:06:47, Custom 1, Net0001: S0005,
i6002 SRC, 854.9375, , 360, , NFM, 1, 00:00:00, 11/27/24 14:06:32, 11/27/24 14:06:32, Custom 1, Net0001: S0005,
6002, 854.9375, CC 0, 359, , NFM, 6, 00:00:02, 11/27/24 14:06:29, 11/27/24 14:06:31, Custom 1, Net0001: S0005,
6002, 854.9375, , 356, , NFM, 5, 00:00:00, 11/27/24 14:06:28, 11/27/24 14:06:29, Custom 1, Net0001: S0005,
1031, 854.9375, CC 0, 363, , NFM, 14, 00:00:02, 11/27/24 14:05:57, 11/27/24 14:06:00, Custom 1, Net0001: S0005,
1031, 854.9375, , 368, , NFM, 13, 00:00:00, 11/27/24 14:05:57, 11/27/24 14:05:57, Custom 1, Net0001: S0005,
6002, 854.9375, CC 0, 357, , NFM, 4, 00:00:02, 11/27/24 14:05:53, 11/27/24 14:05:56, Custom 1, Net0001: S0005,
Since this is just a limit search and I'm not picking up audio I would guess the system is encrypted.
officer_415
SF Bay Area
I just checked with another user in the area and he says he is still able to monitor the system as before, so this seems to be a problem with your scanner. Have you tried deleting the system and reprogramming it from scratch?
es93546
A Member Twice
Yes, I've reprogrammed the entire scanner now at least once. I've been checking all of the items in this one system many times. I've reprogrammed the Mammoth Mountain Ski Area at least 6 times, besides this all systems reprogram. Thanks for checking for me. I will look harder now.
EDIT: As I've said before, this radio has not been good to me. I find it overly complex with little that is intuitive.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
It doesn't look like you have it programmed in as a DMR Trunked system (although nobody would know because you haven't posted screenshots of the actual programming in the scanner). It should be programmed in as DMR/MotoTRBO -> MotoTRBO Trunk.
And for every frequency you add, you need to also add the LCN. If you click on the "Mammoth Mtn Summit" site for instance, you will see any LCN associated with each frequency as well as a color code. You need to program the LCN and color code in for each frequency when you program the frequency in.
cg
Connecticut
I rarely use the database as I am running DSDPlus or SDRTrunk or UniTrunker. I only recall the LCN being in small numbers next to the freqs but I just realized that they are under the sites. So here are the LCNs for the 3 sites in the database:
