I can benefit from a scanner but lack the knowledge to program one correctly. Can anyone help me with a file I can use to upload the frequency information into my BC125AT scanner for Oklahoma County and Custer County Oklahoma?
Any help would be appreciated.
However, your opportunities to listen, with the BC125AT will be limited. For
Custer County, the county sheriff's office is using a couple of frequencies that your scanner could monitor. However, with the exception of Cheyenne-Arapaho tribe, the other public safety services in the county, for Butler, Clinton, & Weatherford, are using DMR, a digital format that your scanner cannot monitor.
For
Oklahoma County, most all of the public safety agencies (cities & the county) are using digital trunked systems which, again, are beyond the capability of your scanner. There are a few analog frequencies that you might be able to listen to, but I suspect those are mostly for backup use in case of a problem with one or more of the trunked systems. Someone in the Oklahoma forum would be more likely to know if any of them are active.
There are several software programs listed on the Wiki page that can be used to program your scanner.
wiki.radioreference.com
If you have downloaded and installed one of them, specify which one so that someone using the same software can better assist you.
