old 410 object id
holmdt
Carson City NV
It has been some time since I added freqs to my scanner. I just Added Sparks FD to my list. The last column is the object id. As you can see it 0's but the software will not let me add +1 to each line. Do I need to change this or is it ok to leave it as a zero?
737mech
Clark County, NV.
Sparks FD
You are adding talkgroups to a trunking system in this case the edacs system sparks fd is using, object id is no concern because the radio will assign them when you upload. Check me on this, upload first then download from scanner and see if there are object id numbers assigned? I never worried about object id's and I have a 410 as well as a 500.
holmdt
Carson City NV
I just uploaded and then downloaded the file and the object id was filled out by the scanner. Thank you for the help.
