One 700mhz problem system
mdsxfire
EDBM
Uxbridge, north of the river Thames
I have one 700mhz phase 2 system (moto) that consistently gives me problems, it will freeze on TGs drop to zero signal, the Ross/site will change to zeroes and the pager will completely reboot at least once every 5 minutes. I have approximately 7 or 8 other 700mhz systems (both Harris and moto) programmed and none of them do this. I reflashed the firmware and deleted them re input the system info with no change. I am 3 miles or less from the closest tower and have 3 different G5’s that all do this on only this system. The system is Somerset county, NJ 700.
N6ML
It's likely a firmware bug. Work with your dealer to get diagnostic logs collected and submitted.
N6ML
It’s been like this since 1.1 through 1.31, and only one system??
The firmware should never crash, no matter how badly one system may be behaving.
As I see it, you have choices:
  1. Get the diagnostics to Unication so hopefully they can debug and fix the firmware issue
  2. Complain to the system owner (good luck with that)
  3. Complain about it here, and hope for ........... ?
mdsxfire
EDBM
Not complaining, just seeing if anyone has had similar issues with this or other systems.
to enable diagnostic logging I have to enable in the pps correct
N6ML
I read a similar report recently, but I don't remember if it was form you or someone else.
There are several things you have to get right (like enabling tracing in the firmware), and there's a "Log Extraction Tool" that you'll need. It's prob best to work through your dealer to get the latest version of the tool, and instructions.
llzel
St Louis, MO
Not unique to 700mhz, I have the same issue on a 800mhz system on a G4, and I am complaining. its a $600 device
6Paul21
Florida
Try changing firmware back to older one and that has solved my problem. Check to see if your radio is G5D model as it seems that the D models do this.
Ed
policefreak
Berlin, NJ
I can't believe it. My G5 running V1.31 does the same thing on this system! However my older G5 running beta firmware does not have an issue with this system.
