KC9NEG
Scanner_freak, could you clarify? Based on current knowledge, to you anticipate difficulty monitoring SAFE-T simulcast, new MECA, or both?
Todd/Indy
Todd/Indy
Since I am not there in Indiana, could you supply an example of a SAFE-T site that is simulcast? I realize that this is OT a bit, but I was unaware of any SAFE-T sites that were simulcast and beg the participants pardon for delving into this for a moment.DiGiTaLD said:There are several areas in Indiana where several Project Hoosier SAFE-T sites are tied together in a simulcast fashion (effectively functioning as one site). I've had no trouble monitoring P25 digital modulation on those thus far. Hopefully such will be the case with the MECA upgrade.
tbhausen said:Based on current knowledge, to you anticipate difficulty monitoring SAFE-T simulcast, new MECA
loumaag said:Since I am not there in Indiana, could you supply an example of a SAFE-T site that is simulcast? I realize that this is OT a bit, but I was unaware of any SAFE-T sites that were simulcast and beg the participants pardon for delving into this for a moment.
rdale said:I'd bank on new MECA issues like MPSCS simulcasts, but not any Safe-T until they go fully P25.
Control is currently on 866.7375 MHz (the alternate). Don't know where you're at, but I'm in NW Johnson County, and I'm able to track it and monitor it fairly well, both analog and digital voice, on both my 96 and 2096 using just 800 MHz rubber ducks. Obviously, some spots are tougher than others, but it still comes through. I'm well outside the intended simulcast "footprint" as well, which I find interesting.tbhausen said:Anybody try monitoring the Boone Co. SAFE-T simulcast with a GRE 500 yet? Guess I oughta do that. I'll program it up and have a listen today.
Check to see what control channel you're using. As of now, Site 121 (the Boone County Simulcast towers) are using the alternate control channel listed above.kadetklapp said:Well, DiGiTaL must be doing all the right things. I have a tremendous amount of problems monitoring the Boone County Simulcast system. All the sites are tied together. I can't pick ANYTHING up on the Boone County tower freq at all. The only traffic I hear, when it does trickle thru, is off the Crawfordsville tower. And even then it seems it's usually medical. I rarely will pick up Boone County Sheriff Dispatch. Even with the scanner in the town of Thorntown, I hear nothing, unlesss it comes over Crawfordsville's tower.
I also have no problems with Site 129 (Hendricks County simulcast towers) but I'm pretty close.aaron315 said:I monitor the Hendricks Co site daily without problems.
So what you're saying is that there's a difference between the simulcasting of P25 digital voice on a true P25 system (9600 bps control channel) versus simulcast P25 digital voice on a Motorola SmartZone (3600 bps control channel) system?scanner_freak said:Two completely different set-up's. Motorola P25 simulcast systems use Linear Simulcast Modulation, CQPSK, which is very difficult for the current scanners to decode. Granted, reception is best when inside the coverage "foot print" so those in that area will be better off than those not. But from someone who monitors a P25 CQPSK simulcast system every day, don't get your hopes up![]()
DiGiTaLD said:So what you're saying is that there's a difference between the simulcasting of P25 digital voice on a true P25 system (9600 bps control channel) versus simulcast P25 digital voice on a Motorola SmartZone (3600 bps control channel) system?
scanner_freak said:That is correct. Motorola P25 systems use LSM, which is the 12.5 kHz version of CQPSK. This is extremely difficult for the scanners to decode. You will not see these issues in the current SAFE-T simulcast sites as they do not use LSM . You cannot compare the twoFor those who have never heard it, Here is what a P25 CC sounds like. This is what you will be listening to hear.
Good information. Thanks for the clarification! I have done some monitoring of Illinois Starcom-21, which is a true P25 system with my PRO-96, and had no problems decoding the digital voice, but the site I was listening to was a single site, not multiple sites set up in simulcast fashion. It sounds as though the problem comes up for our scanners when you get true P25 and simulcast together.scanner_freak said:That is correct. Motorola P25 systems use LSM, which is the 12.5 kHz version of CQPSK. This is extremely difficult for the scanners to decode. You will not see these issues in the current SAFE-T simulcast sites as they do not use LSM . You cannot compare the two![]()
GTO_04 said:In your opinion which of the handheld digital scanners will do the best decoding with that system? The 396, the Pro-96, or the PSR-500? The reason I ask is that I am considering the purchase of a PSR-500 and right now I am only used to SAFE-T which doesn't use LSM.
GTO_04
DiGiTaLD said:Good information. Thanks for the clarification! I have done some monitoring of Illinois Starcom-21, which is a true P25 system with my PRO-96, and had no problems decoding the digital voice, but the site I was listening to was a single site, not multiple sites set up in simulcast fashion. It sounds as though the problem comes up for our scanners when you get true P25 and simulcast together.
scanner_freak said:Hands down the PSR-500 and it still has some issues but it is by far the best (I have them all) I have heard on the Cincinnati system, which is LSM CQPSK. Don't hesitate on the 500, it's an amazing scanner once you get the hang of it.
Most certainly. It affects pretty much anything you listen to on 800 MHz, MECA or otherwise. The intermod from Nextel and cell sites is horrible. Most of the time, though, unless you are right on top of an offending transmitter, the attenuator will make the signal listenable again. Don't expect the digital voice to cure the problem, either. Intermod from strong, nearby cellular and Nextel sites still blows out digital voice to the point where it is unintelligible. I can be within a mile of the local SAFE-T site here in Greenwood, specifically at the intersection of IN-135 and County Line Road, and get blown out by a cellular/Nextel site to the southeast of that intersection, and another to the southwest. The attenuator usually cuts down the interference enough to hear the SAFE-T site again, but its really bad without it.GTO_04 said:Sometimes MECA reception is pretty good, at other times it is full of static even at close range. I just wonder if they still aren't having problems with NEXTEL interference.
DiGiTaLD said:Most certainly. It affects pretty much anything you listen to on 800 MHz, MECA or otherwise. The intermod from Nextel and cell sites is horrible. Most of the time, though, unless you are right on top of an offending transmitter, the attenuator will make the signal listenable again.
DiGiTaLD said:Don't expect the digital voice to cure the problem, either. Intermod from strong, nearby cellular and Nextel sites still blows out digital voice to the point where it is unintelligible.
w8fcc said:Also some of Hancock County has started as well.
