OnQue - NEXEDGE System
mbstone99
Hamilton, Ontario
You must be pretty close to where Graeme and I used to live. I was at 121 Hunter St, top floor facing the lake, corner of Bay St.
Unable at the time to hear the Hamilton Simcoe frequency at the time but Toronto, Peel, no problem for their 800 Mgh systems and fleetnet.
I think WZ1 lived in one of the lower cities tallest condos at the time, all this scanner 'talent' and I did not meet up and become friends with Graeme or WZ1 until we all moved.
I am just a stones throw away from there at Bay & Duke, also facing towards the lake. I can get the Halton, Peel and Toronto trunks without any problems and sometimes even the Durham trunk.
Matt
mmisk
Ottawa Canada
Tower Work for DMR reception
Nice! How high? A yagi on a rotor up there would be awesome...
Hi Forts,
Well I took advantage of the warm weather and did some tower work.
- replaced the coax to my 2 metre antenna with new RG 213
- installed a 1/4 wave 450 ground plane and LMR 400 coax
- took down the 2.5 dish
- replaced the dish antenna with a TV UHF corner reflector yagi turned vertically with LMR 400
The TV UHF ant works great, I heard about using old TV antennas this way and always wanted to give it a try.
The 450 ground plane also seems to work very well. Everything is above the tree line.
What a difference on UHF and 800. I have a huge list of DMR and NXDN signals now.
Plus I can rotate the TV antenna
I would like to hook up with other listeners in the Ottawa area to compare notes.
Mike
mmisk
Ottawa Canada
Hawkesbury NXDN
DaveH; "There appears to be a site at Vankleek Hill (Hawkesbury/ Lachute area) 12.5kHz apart said:
Dave,
I picked up a weak NXDN on 460.6125.
DSD+ is reporting it as NID:202 Site 30
Here is what I have verified for site 202:
CH refers to the voice channel numbers
1 202 CH 1,2 451.4500 MHz
1 202 CH 3,4 451.0750 MHz
1 202 CH 5,6 460.0250 MHz
2 202 CH 1,2 452.2375 MHz
2 202 CH 3,4 452.3125 MHz
2 202 CH 5,6 452.5375 MHz
3 202 CH 1,2 463.9625 MHz (Have not found a third frequency for this site)
3 202 CH 3,4 460.6375 MHz
5 202 CH 1,2 463.3750 MHz
5 202 CH 3,4 451.4750 MHz
5 202 CH 5,6 460.3875 MHz
12 202 CH ? 464.0125 MHz
12 202 CH ? 451.4000 MHz
13 202 CH 1,2 460.5375 MHz
13 202 CH 3,4 461.2625 MHz
13 202 CH 5,6 461.4875 MHz
21 202 NXDN48 462.2125 MHz
21 202 NXDN48 460.2875 MHz
22 202 NXDN48 452.1625 MHz
22 202 NXDN48 452.7375 MHz
30 202 NXDN48 460.6000 MHz (Not verified yet)
30 202 NXDN48 460.6125 MHz
32 202 NXDN48 460.2625 MHz
EricCottrell
Boston, Ma
Dave,
Hello,
You are mixing the GOTRBO DMR Network with the OnQue NXDN network. Two separate systems that just happen to use the same id number.
73 Eric
Saint
Fort Erie Ontario Canada
Two Systems
Dave,
These are the two systems
OnQue Trunking System, Multiple Locations, Ontario - Scanner Frequencies
And the other is,
GOTRBO Network Connect Plus (202) Trunking System, Multiple Locations, Ontario - Scanner Frequencies
Steve
mmisk
Ottawa Canada
two separate systems with the same ID
Thanks everyone for the info.
I did not realize there were two separate systems with the same ID
Now that I have much improved receive for 450 I will have to be very careful about this.
Mike
jasoyeom
Norfolk County
I noticed Norfolk Disposal on the Multi-County Groups. Has this been confirmed? I know they are currently using Oxford Communications LTR in Norfolk County. Maybe they are using a different system outside of Norfolk County?
mbstone99
Hamilton, Ontario
I logged in my logs and I have logged their talkgroup on the Hamilton site.
Matthew
