SDS100/SDS200: opening.bmp issues
jake_Braker
Somewhere in NC
Hey y'all!
I was going through some forums last night and I saw you're able to change the opening.bmp file and I was testing it out with some of the files other users provided and it worked no issues. However, when I tried to make my own photos, I can't get it to work. I used paint.net and making sure it fits in the 240x320 size with 24 bit but still nothing. I was wondering if anyone can help. I've attached the photo I'm trying to use in the same size
jonwienke
More Info Coming Soon!
VA
It has to be a 24-bit (8 bits per color channel) bitmap image, not a jpeg with a bmp file extension or anything else.
jake_Braker
Somewhere in NC
I save it as a .BMP file, however it's a banned file type from RR so I had to copy/paste from paint.net
fxdscon
¯\_(ツ)_/¯
Hey y'all!
For a custom Opening Graphic Boot Screen For The SDSX00 Scanners, use a graphics editing program to set these parameters...
(1) The image must be in the .bmp format (you can't just change a jpg or png file extension to bmp, it must be "saved as" a bmp format in a graphics editing program).
(2) The image must be named opening.bmp (lower case only)
(3) The image must be at 24 bit color depth (16 million colors)
(4) For use in the SDS100 the image must be exactly 240 x 320 (width x height)
(5) For use in the SDS200 the image must be exactly 480 x 320 (width x height)
(6) The image must be placed in the BCDx36HP Folder on the scanner's SD card (same location as the profile.cfg and other files).
If even one of the above parameters is not correct, the scanner won't recognize the graphic at all, and will boot up with whatever text was there previously.
Once the graphic is in place on the card and working, it won't be overwritten by any "writes" from Sentinel to the scanner, regardless of what the "opening message" text is set to in the Sentinel Profile Editor. The scanner will always boot with the graphic if it's set with the correct parameters, and in the correct location on the SD card. Reformatting the card or using the "Clear User Data" function will, of course, delete the custom graphic from the card.
To change back to the original opening screen text, just delete the .bmp graphic file you put in the folder on the SD card, and restart the scanner.
jake_Braker
Somewhere in NC
I followed those instructions to a T. Does the file size matter? I noticed the ones I downloaded are 226Kb but the ones I try to make are normally 11-16KB
fxdscon
¯\_(ツ)_/¯
It is being saved as a .bmp file as well
When I download the graphic in your post #1 (png format) and convert it to bmp format keeping the color depth at 24 bit, the resulting file size is 225Kb.
jake_Braker
Somewhere in NC
Can you post the .TXT file for it? I just tried it and the conversion is still at 28.3KB
rdlinn
Western Grove
Nevermind, I got it working!
I'm having the same problem, mine is 320x240 BMP and 24 bit and saved in the bcdx36hp folder. i can connect the scanner and double click and view the pic but still wont load on the scanner,it's 228kb. saved as BMP in that folder do you have to write to scanner or just save to that folder?
jake_Braker
Somewhere in NC
It has to be 226kb
I'm not fully sure about writing to the scanner, I would assume not.
fxdscon
¯\_(ツ)_/¯
Did you save that file with the bmp in caps like in your post? It should be in lower case. Check line (2) in post #4 above.
rdlinn
Western Grove
it's an SDS 100, yes the BMP is in capital letters. I've tried paint.net and paint 3d... how can you change BMP to bmp?
