OPP antennas
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
Heard Radio Service do a Comms Check with Orillia on 2TAC05 via Fenelon tower today, and also on last Friday.
Mentioned he was in a garage, and had poor signal, so clearly mobile equipment being worked on.
Had a couple of Kawartha Lakes OPP vehicles park in front of the house which gave a good opportunity to look at the mobile antennas.
Whip antenna in the middle appears to be short and likely 700 MHz now instead of 411 MHz for VR.
gary123
The antennas used on OPP/EMS the vehicles are
1 1/4 wave 700MHS DVRS antenna,
2 1/2 wave VHF antenna (the loading coil on the base is not a NMO to threaded adapter) *need reverification on exact model used
3 2 in round 1/12 in high puck antenna for GPS
4 sharkfin antenna for the MPS(terminal)
exkalibur
York, Ontario
3 2in round 1/12in high puck antenna for GPS
The VHF antenna posted in rneal's post is a Sinclabs SVT-1180-EX. The 700MHz is a Sinclabs SUT-5120.
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
144 MHz 1/4 wave antenna should be about 19.5" long, above the base insulator, including spring. (Mobile to Site)
410 MHz 1/4 wave antenna should be about 6.8" long, above the base insulator, including spring. (Old VR)
800 MHz 1/4 wave antenna should be about 3.5" long, above the base insulator, including spring. (New VR)
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
Possibly a Larsen NMO GPS.... Do these photos look like the same GPS puck?
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
VHF
SVT-1180-EX-S, or SVT-1180-SP-S
Sinclair
VHF
118 MHz (Lowest frequency whip can be cut to)
EX = Excelsior base
SP = Excelsior spring pin base with integral sealing gasket
-S for shock spring
700 MHz
SUT-5120SP-S Mobile omni, 0 dBd, 512-970 MHz
Sinclair
UHF
512 MHz (Lowest frequency whip can be cut to)
-S for shock spring
gary123
In my opinion Sinclairs online catalog sucks. One image containing 6 different antenna configurations, no detailed image/description of the various antenna base. I think we have satisfied our curiosity on the antennas. FYI the mobile radios are APX2500BN with E5 remote heads.
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
That's Interesting.... APX2500BN is a nice radio.. in VHF M24KSS9PW1BN
But AFAIK it only comes with the 02 control head. 512 or 1000 channels.
But hey, if you're buying 10-15,000 radios, I'm sure Moto lets you order off-menu :)
rneals
Rosco P. Coltrane
Kawartha Lakes, ON
Re the OPP GPS antenna.... It occurs to me that these new radios will have WiFi clients and require an antenna for that.
Motorola AN000163A01 GPS+WiFi antennas is the Moto solution for that.
A typical use case is using Moto Radio Manager to push new firmware and codeplug to the mobile while it's parked in the parking lot at the office/detachment. An external/roof mounted antenna is likely needed to reach across the parking lot, particularly if the radio body is buried in the Explorer Utility floor pan area and covered with traffic cones, flares and misc junk.
images
exkalibur
York, Ontario
