Wrong.Also, using FTO on a trunked system is not possible unless paging is always done over a particular frequency (not talkgroup).
Idk bro...In my area, the audio quality for tone outs is horrible. They sound tremendously overdriven. Also, using FTO on a trunked system is not possible unless paging is always done over a particular frequency (not talkgroup).
Hello, I'm curious as to what your thoughts are on why this can't be done over a talkgroup? I'm doing it in two different County's over two different ASTRO 25 TRS. The subscribers are a diverse bunch of HT's, mobiles, as well as Unication Pagers. Please elaborate, and thanks!In my area, the audio quality for tone outs is horrible. They sound tremendously overdriven. Also, using FTO on a trunked system is not possible unless paging is always done over a particular frequency (not talkgroup).
If you listen to 154.205 you can hear they are two separate tones. On the P25 talkgroup they are close enough that it sounds like a long tone.Seems the Orange County wiki for fire tone outs needs a bit of updating as even many EMS agencies have additional tones now then when that wiki was created. For instance Montgomery EMS now has an all call, sounds like Newburgh also has two new set of tones.
But... I do have a question that has been inking me for a while to find out the reason or what it is used for. But Cornwall FD use to have 3 set of tones which the Pager and then the other two sets was for Cornwall and Mountainville sirens to be set off but now here 2 set of tones and then a long tone. Anyone know what it is used for or the purpose? The only long tones that have been used in OC was the battalion tones.
Hi. I found the codes to be different from what's listed on Wiki. For Silver Lake FD you want to use 54, 64 for the 2 toneI am trying to set up Silver Lake fire in my G4. (paging) It works fine with Circleville but not Silver Lake. I tripled checked the tones I use via the wiki info. Anyone have suggestions?
Tones do not belong in the database. Stuff like that belongs in the wiki, which any user can edit (do not submit wiki stuff to the database).Are there any others you noticed? Maybe submit them to Radio reference data base.
You were right! the different tone worked. Thank You so much!Hi. I found the codes to be different from what's listed on Wiki. For Silver Lake FD you want to use 54, 64 for the 2 tone
