Orion MACRO setting help
timkilbride
Linn Co Iowa
I am running a dual radio with one control head setup.
Radio A has a channel in it to activate a door opener. I have setup a MACRO assigned to a control head button to automatically go to that channel and key the door so it will open/close whether your on Radio A or Radio B. When Radio A is selected, everything works fine. Goes to correct system/group, opens door, and goes back to Home System/Group like it is suppose to. When Radio B is selected, it will select Radio A, open door, go back to Home System/Group, then it hangs up. I'm trying to get it to go back to Radio B.
Here is the MACRO setup for Radio B:
MACRO PRESS
KEYSTROKE
1 RAD1 PRESS
2 MACDY PRESS AND RELEASE
3 OPT1 PRESS
4 MACDT PRESS AND RELEASE
5 ENC1 PRESS
6 MACDY PRESS AND RELEASE
7 MACDY PRESS AND RELEASE
8 MACDY PRESS AND RELEASE
9 SG1 PRESS
10 MACDY PRESS AND RELEASE
11 RAD2 PRESS
At keystroke 11, I have also tried "RAD" which is suppose to select the non-selected radio.
Any ideas? I have tried adding more delay after keystroke 9, but it won't go back to Radio B.
Tim
