Outdated Info ?
millam
Old Radio Guy
Just saw this today, Info Outdated. Any ideas on what it means?
Mil
dave3825
Suffolk County NY
Are you anywhere near those sites? I have one doing that on a neighbor site that's connected via issi. Been meaning to get DSDPLus to decodes its cc stream to see if it corrects.
millam
Old Radio Guy
yea just down the road from 6.1 and can decode 6.2 pretty good. Tell me how to setup a recording of the cc stream and I'll
do that. Don't know what issi is. Send me what you want me to do via a PM if you will. There is something going on with Dale
county's 700 system but I don't know what it is. Some sites have gone quiet, 6.3 and 6.5.
Mil
dave3825
Suffolk County NY
I am not from that area. You would need to get your DSDPlus to lock on the control channels from those sites and see what it writes in the DDPlus.p25data file.
millam
Old Radio Guy
Contents of these files;
DSDPlis.p25data.file
; DSD+ 2.457; P25 data
; this file is auto-maintained by DSD+
; editing of this file should be limited to removal of data known to be incorrect or outdated
MHzDecimalPad = 0 ; controls how DSD+ formats all channel frequencies; range = 0 to 6
Network: BEE00.46B
Bandplan #0: Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
Bandplan #1: Base=762.00625 Offset=+30 Spacing=6.25 BW=12.5
Bandplan #2: Base=851.0125 Offset=-45 Spacing=12.5 BW=12.5 Slots=2
Bandplan #3: Base=762.00625 Offset=+30 Spacing=12.5 BW=12.5 Slots=2
Bandplan #4: Base=935.0125 Offset=-39 Spacing=12.5 BW=12.5
Bandplan #5: Base=935.0125 Offset=-39 Spacing=12.5 BW=12.5 Slots=2
Site: 6.1 NAC=460
Neighbor: BEE00.46B-6.2
Neighbor: BEE00.46B-6.3
Neighbor: BEE00.46B-6.4
Neighbor: BEE00.46B-6.5
Channel 0-117: 851.7375 CC
Channel 0-183: 852.15 SCC
Channel 0-245: 852.5375 SCC
Channel 0-295: 852.85 SCC
Channel 0-339: 853.125 VOICE
Channel 0-529: 854.3125 VOICE DATA
Channel 0-617: 854.8625 VOICE
Channel 0-657: 855.1125 DATA
Channel 0-741: 855.6375 VOICE
Site: 6.2 NAC=46D
Channel 1-1306: 770.16875 CC
Channel 1-1346: 770.41875 SCC
Channel 1-1620: 772.13125 SCC
Channel 1-1752: 772.95625 VOICE
Channel 1-2060: 774.88125 VOICE
Site: 6.3
Channel 1-1328: 770.30625 CC
Site: 6.4
Channel 1-1280: 770.00625 CC
Site: 6.5
Channel 1-1176: 769.35625 CC
DSDPlus.event file
2024/05/13 17:05:56 DSD+ 2.457 / Fast Lane Release
2024/05/13 17:05:56
2024/05/13 17:05:56 Base files test: All files passed
2024/05/13 17:05:56 P25 data loaded; 1 network, 5 sites, 11 channels
2024/05/13 17:05:56 Fusion decoding enabled
2024/05/13 17:05:56 D-STAR decoding enabled
2024/05/13 17:05:56 NXDN4800 decoding enabled
2024/05/13 17:05:56 NXDN9600 decoding enabled
2024/05/13 17:05:56 DMR/MotoTRBO decoding enabled
2024/05/13 17:05:56 P25 Phase 1 and Phase 2 decoding enabled
2024/05/13 17:05:56 X2-TDMA decoding enabled
2024/05/13 17:05:56 ProVoice decoding enabled
2024/05/13 17:05:56 Current site: 6.1
2024/05/13 17:05:56 Current network: BEE00.46B
2024/05/13 17:05:56 Group call; TG=60339 Ch=853.125 Pri0 1s
2024/05/13 17:05:56 Current site: BEE00.46B-6.1
2024/05/13 17:05:56 FM demodulated P25p1 PSK signal detected
2024/05/13 17:05:56 Use a FMPA/FMPP/FMP24 link and correct channel bandwidth to decode
2024/05/13 17:05:57 BEE00.46B-6.1 neighbor: Site BEE00.46B-6.5; CC=1-1176 769.35625 ISOLATED
2024/05/13 17:05:57 BEE00.46B-6.1 neighbor: Site BEE00.46B-6.3; CC=1-1328 770.30625 ISOLATED
2024/05/13 17:05:57 BEE00.46B-6.1 neighbor: Site BEE00.46B-6.4; CC=1-1280 770.00625 ISOLATED
2024/05/13 17:05:58 BEE00.46B-6.1 neighbor: Site BEE00.46B-6.2; CC=1-1306 770.16875 ISOLATED
2024/05/13 17:06:01 Group call; TG=60337 Src=EXTERNAL Ch=854.8625 1s
2024/05/13 17:06:01 Group call; TG=60339 Src=EXTERNAL Ch=855.6375 7s
2024/05/13 17:06:03 Deregistration; RID=6003481
2024/05/13 17:06:05 Group call; TG=60337 Src=EXTERNAL Ch=854.3125 1s
2024/05/13 17:06:52 DSD+ 2.457 / Fast Lane Release
2024/05/13 17:06:52
2024/05/13 17:06:52 Base files test: All files passed
2024/05/13 17:06:52 P25 data loaded; 1 network, 5 sites, 15 channels
2024/05/13 17:06:53 Fusion decoding enabled
2024/05/13 17:06:53 D-STAR decoding enabled
2024/05/13 17:06:53 NXDN4800 decoding enabled
2024/05/13 17:06:53 NXDN9600 decoding enabled
2024/05/13 17:06:53 DMR/MotoTRBO decoding enabled
2024/05/13 17:06:53 P25 Phase 1 and Phase 2 decoding enabled
2024/05/13 17:06:53 X2-TDMA decoding enabled
2024/05/13 17:06:53 ProVoice decoding enabled
2024/05/13 17:06:53 Current network: BEE00.46B
2024/05/13 17:06:53 Current site: BEE00.46B-6.2
2024/05/13 17:06:53 Group call; TG=61006 Ch=772.95625 Pri0 1s
2024/05/13 17:06:56 Group call; TG=61006 RID=6010141 Ch=774.88125 5s
2024/05/13 17:07:02 Group call; TG=61006 RID=6010179 Ch=774.88125 2s
2024/05/13 17:07:04 Registration; RID=2901276 ACCEPT
2024/05/13 17:07:04 Affiliation; RID=2901276 TG=29200 ACCEPT
2024/05/13 17:07:08 Registration; RID=6010033 ACCEPT
2024/05/13 17:07:08 Affiliation; RID=6010033 TG=29206 ACCEPT
; 33 records
millam
Old Radio Guy
CC1log contents
DSD+ 2.457
Current working directory is "C:\SSD\dsd_5_dec"
Program role is single-receiver control/rest/traffic channel decoder
Filename modifier set to 1
2024.05.13 17:18:36 Adding timestamps to console log file entries and console screen data
2024.05.13 17:18:36 Adding NAC/RAN/DCC/RAS data to event log file entries
2024.05.13 17:18:36 The -v command line parameter is no longer supported.
2024.05.13 17:18:36 Use the DSD+ menus to adjust this parameter.
2024.05.13 17:18:36 Appending synthesized audio to file '1R-DSDPlus#1.wav'
2024.05.13 17:18:36
2024.05.13 17:18:36 Assuming FMPA/FMPP/FMP24 is signal source; auto polarity detect is disabled
2024.05.13 17:18:36
2024.05.13 17:18:36 audio output device #1 = 'Headphones (Realtek(R) Audio)'
2024.05.13 17:18:36 audio output device #2 = 'Speakers (Realtek(R) Audio)'
2024.05.13 17:18:36 audio output device #3 = 'CABLE Input (VB-Audio Virtual C'
2024.05.13 17:18:36
2024.05.13 17:18:37 audio output device #1 (Headphones (Realtek(R) Audio)) initialized
2024.05.13 17:18:37
2024.05.13 17:18:37
2024.05.13 17:18:37 Testing Base Files:
2024.05.13 17:18:37
2024.05.13 17:18:37 File: FMP24.exe PASS
2024.05.13 17:18:38 File: FMPA.exe PASS
2024.05.13 17:18:38 File: FMPP.exe PASS
2024.05.13 17:18:38 File: FMP-Map.exe PASS
2024.05.13 17:18:38 File: LRRP.exe PASS
2024.05.13 17:18:38 File: Survey.exe PASS
2024.05.13 17:18:38 File: airspy.dll PASS
2024.05.13 17:18:38 File: lame_enc.dll PASS
2024.05.13 17:18:38 File: libfftw3f-3.dll PASS
2024.05.13 17:18:38 File: libusb-1.0.dll PASS
2024.05.13 17:18:38 File: msvcr90.dll PASS
2024.05.13 17:18:38 File: msvcr100.dll PASS
2024.05.13 17:18:38 File: msvcrt.dll PASS
2024.05.13 17:18:38 File: pthreadVCE2.dll PASS
2024.05.13 17:18:38 File: rtlsdr.dll PASS
2024.05.13 17:18:38 File: rtlsdr_FC0012.dll PASS
2024.05.13 17:18:38 File: rtlsdr_V4.dll PASS
2024.05.13 17:18:38 File: sdrplay_api.dll PASS
2024.05.13 17:18:38
2024.05.13 17:18:38 18 files checked
2024.05.13 17:18:38 18 files passed
2024.05.13 17:18:38
2024.05.13 17:18:38 Base files test: All files passed
2024.05.13 17:18:38 P25 data loaded; 1 network, 5 sites, 17 channels
2024.05.13 17:18:38 247 frequency records loaded; 3 incomplete fields
2024.05.13 17:18:38 1236 radio records loaded
2024.05.13 17:18:38 371 group records loaded
2024.05.13 17:18:38 2 site records loaded
2024.05.13 17:18:38 13 network records loaded
2024.05.13 17:18:38 0 site loader records loaded
2024.05.13 17:18:38 Fusion decoding enabled
2024.05.13 17:18:38 D-STAR decoding enabled
2024.05.13 17:18:38 NXDN4800 decoding enabled
2024.05.13 17:18:39 NXDN9600 decoding enabled
2024.05.13 17:18:39 DMR/MotoTRBO decoding enabled
2024.05.13 17:18:39 P25 Phase 1 and Phase 2 decoding enabled
2024.05.13 17:18:39 X2-TDMA decoding enabled
2024.05.13 17:18:39 ProVoice decoding enabled
2024.05.13 17:18:39 Initiating FMPx link using link ID 20030...
2024.05.13 17:18:39 FMPx link established; link ID = 20030
2024.05.13 17:18:39 Sync:+P25p1 TSDU CRC FAIL
2024.05.13 17:18:39 Sync:+P25p1 NAC:460 TSDU SYNC_BCST US=0 IST=1 MMU=0 MC=0 VL=0 LTO=-5h 2024/05/13 22:18 uSlot=5180
2024.05.13 17:18:39 IDEN_UP_TDMA ID=3 Base=762.00625 Offset=+30 Spacing=12.5 BW=12.5 Slots=2
2024.05.13 17:18:39 IDEN_UP ID=4 Base=935.0125 Offset=-39 Spacing=12.5 BW=12.5
2024.05.13 17:18:39 Sync:+P25p1 NAC:460 TSDU IDEN_UP_TDMA ID=5 Base=935.0125 Offset=-39 Spacing=12.5 BW=12.5 Slots=2
2024.05.13 17:18:39 RFSS_STS_BCST SysID=46B LRA=0 RFSS=6 Site=1 CC=0-117 SC=70
2024.05.13 17:18:39 NET_STS_BCST WACN ID=BEE00 SysID=46B LRA=0 CC=0-117 SC=70
2024.05.13 17:18:39 Sync:+P25p1 NAC:460 TSDU SN-DATA_CHN_ANN_EXP DSO=00 TXch=855.1125 RXch=none DAC=0001
2024.05.13 17:18:39 MOT_SYSPARMS_BCST
2024.05.13 17:18:39 MOT_BSI_GRANT Null BSI ch=851.7375
2024.05.13 17:18:39 Sync:+P25p1 NAC:460 TSDU ADJ_STS_BCST SysID=46B LRA=0 RFSS=6 Site=3 CC=770.30625 SC=70 CFVA=2: ISOLATED
2024.05.13 17:18:39 SCCB RFSS=6 Site=1 [ch=852.85 SSC=04] [ch=852.15 SSC=04]
2024.05.13 17:18:39 MOT_SCAN_MARKER
2024.05.13 17:18:39 Sync:+P25p1 NAC:460 TSDU SYNC_BCST US=0 IST=1 MMU=0 MC=0 VL=0 LTO=-5h 2024/05/13 22:18 uSlot=5220
2024.05.13 17:18:39 IDEN_UP ID=0 Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
2024.05.13 17:18:39 IDEN_UP ID=1 Base=762.00625 Offset=+30 Spacing=6.25 BW=12.5
2024.05.13 17:18:39 Sync:+P25p1 NAC:460 TSDU IDEN_UP_TDMA ID=2 Base=851.0125 Offset=-45 Spacing=12.5 BW=12.5 Slots=2
2024.05.13 17:18:39 RFSS_STS_BCST SysID=46B LRA=0 RFSS=6 Site=1 CC=851.7375 SC=70
2024.05.13 17:18:39 NET_STS_BCST WACN ID=BEE00 SysID=46B LRA=0 CC=851.7375 SC=70
2024.05.13 17:18:40 MOT_SYSPARMS_BCST
2024.05.13 17:18:40 ADJ_STS_BCST SysID=46B LRA=0 RFSS=6 Site=4 CC=770.00625 SC=70 CFVA=2: ISOLATED
2024.05.13 17:18:40 Sync:+P25p1 NAC:460 TSDU SCCB RFSS=6 Site=1 [ch=852.15 SSC=04] [ch=852.5375 SSC=04]
2024.05.13 17:18:40 FM demodulated P25p1 PSK signal detected; adjusting channel bandwidth
2024.05.13 17:18:40 MOT_SCAN_MARKER
2024.05.13 17:18:40 SYNC_BCST US=0 IST=1 MMU=0 MC=0 VL=0 LTO=-5h 2024/05/13 22:18 uSlot=5250
2024.05.13 17:18:40 Sync:+P25p1 NAC:460 TSDU IDEN_UP_TDMA ID=3 Base=762.00625 Offset=+30 Spacing=12.5 BW=12.5 Slots=2
2024.05.13 17:18:40 IDEN_UP ID=4 Base=935.0125 Offset=-39 Spacing=12.5 BW=12.5
2024.05.13 17:18:40 IDEN_UP_TDMA ID=5 Base=935.0125 Offset=-39 Spacing=12.5 BW=12.5 Slots=2
2024.05.13 17:18:40 Sync:+P25p1 NAC:460 TSDU RFSS_STS_BCST SysID=46B LRA=0 RFSS=6 Site=1 CC=851.7375 SC=70
2024.05.13 17:18:40 NET_STS_BCST WACN ID=BEE00 SysID=46B LRA=0 CC=851.7375 SC=70
2024.05.13 17:18:40 SN-DATA_CHN_ANN_EXP DSO=00 TXch=855.1125 RXch=none DAC=0001
2024.05.13 17:18:40 Sync:+P25p1 NAC:460 TSDU MOT_BSI_GRANT Null BSI ch=851.7375
2024.05.13 17:18:40 ADJ_STS_BCST SysID=46B LRA=0 RFSS=6 Site=2 CC=770.16875 SC=70 CFVA=2: ISOLATED
dave3825
Suffolk County NY
The log is listing some sites as isolated. Pretty sure that's known as site trunking which means the sites lost connection or were shut off by system admins for whatever reason. They should still function but I believe independently. When they are restored DSDPlus should pick up on it and hopefully correct itself.
millam
Old Radio Guy
Yea 3 of the 5 sites aren't transmitting anymore and the 2 that are don't show any neighbors.
Mil
