Repeaters 2 meters / 440 etc are a thing of the past.
Not if the lengthy waiting lists for frequency coordination are any indicator.
In my area of the country, they are almost unused to the point of where the FCC is threatening to take away the 440 mhz portion of the bands due to all the inactivity.
Any reallocation of amateur bands has nothing to do with the activity level. Money is the motivation, and the perception that certain pieces of spectrum will bring more value than whatever the previous use was.
Once a person gets a general class license - for the most part - as soon as they get a HF rig and a good antenna system - they abandon the 2 meters crap and migrate up into the HF.
So, where does that leave all the extra class hams that operate exclusively on repeaters? I personally know quite a few.
A smart person would already know that no one owns a particular frequency.
What this means is that you do not have to have permission from anyone to build a actual repeater and you do not have to ask permission from a repeater council to get a pair of coordinated frequencies
By definition, if you want a
coordinated frequency, you must go through a coordinator.
The repeater council is made up of repeater owners - who by the buddy system - trys to keep out all the undesirables...
The sole purpose of coordination is to try to minimize or prevent interference before it starts. It stands to reason that a repeater coordinating council would have a membership of repeater owners, as opposed to, say, repeater users. The owners are the ones who have a more vested interest in seeing that the process is done correctly. There are exceptions to that, but in general those exceptions do not work well.
When I bounced the repeater owners about it - their reply was that it was allowed to do it because it is MY REPEATER!
There may be parameters that their system is operating under that you're not aware of.
The bottom line is that you have to use a Fris Transmission calculator to determine how much ERP you will have.
You have to use a Longely Rice Calculator to determine how far it will transmit once you build it.
You have to use Google Earth to determine where the transmitter is going to be built and you have to have a exact coordinates for the area and a elevation AMSL to apply for the license from the FCC.
There are a lot more tools than that at the disposal of people wanting to put up a repeater. And since this topic relates to amateur repeaters, the comments about GMRS and the FCC don't really apply.
The repeater council - if they want to be real pricks - can charge you at least $650 to figure out all this stuff for you and to give you a pair for frequencies. But then again - they will put you on hold at least 2 years and even when you get your pairs - you might be limited to 50' of HAAT and 50 watts to keep you from interfering with other coordinated pairs in the area.....
For amateur repeaters!? I don't believe it.
As for technical limitations on repeater coordination, this is typical, and is necessary to insure that the technical basis for which a particular coordination is issued is maintained by the repeater owner.
The next step above that is - no club is allowed to charge a FEE - for a person to be allowed to use the repeater... So this has to be funded by some type of general fund or out of your own pocket.
This is untrue. Amateur repeater owners are allowed to require membership, and membership is allowed to be contingent on dues being paid.
VHF is very susceptible to noise.
Be it electrical noise - fans, switches, power lines, fence chargers, motor brush noise etc.
Atmospheric noise - lightning
Interference from other signals in the same area - including 3rd order harmonic's.
A gross over simplification...
UHF is limited to LOS communications.
UHF is like shining a flashlight - it does not go up one hill and down the next.
It does not shine into the side of one hill and come out the other side - like a Buggs Bunny cartoon.
It does not bend around the earth.
Eventually the signal travels out of the atmosphere - if it does not have anything to bounce off - and is lost in space - like the old television program.
Another gross over simplification...
It's downfall is that electric costs are more for UHF then for VHF because VHF will travel further with less effort then UHF.
WHAT!!?? LOL! I have no idea what you're talking about here, but it IS funny. :lol:
So the question is - why would you want to build your own repeater - when you can use someone elses for free?
A valid question, but to clarify, you can use someone else's OPEN repeater for free.
The bottom line is - unless you can afford to pay someone to monitor what goes on - on your repeater, while you are at work, asleep in your bed, away on vacation, sick in the hospital etc - there is no way you can afford to maintain a repeater of any size.
There are thousands of repeaters who's owners can afford to maintain their repeaters. Where on earth do you come up with this stuff?
Then on top of all this - you have to have a fence around your repeater to keep others away from the tower and you have to have some type of security system to keep intruders out of your repeater building.
Building a repeater, and building a repeater site are two completely different tasks. Please don't confuse the two.
Well unless you throw another nickle in the juke box - I am done on this one, my two cents has run out.
I guess I threw another nickle in. There was a lot of misinformation in your post.
