P25 Radios
K2NEC
NA
Depends what you're looking to do with it. Technically probably the Saber or XTS3000, I think I saw one the other day for $20. But if you're actually looking to program and use it regularly something like the XTS1500 would be better.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
New......... Icom is least expensive, then Kenwood, then Moto (I am not up to speed on Thales, Harris, BK, etc, so they are in there somewhere). TT
K2NEC
NA
Considering this is the Motorola thread I'm gonna go out on a limb and say OP is asking specifically about Motorola...
nokones
Sun City West, AZ
Hey all. What is the most inexpensive radio that is p25 capable?
I'm assuming you want to use this radio on conventional radio channels with the P25 Digital modulation feature, then you won't need any radio flashed for trunking. Essentially, any radio flashed with the G806 or Q806 feature code will allow you to modulate P25 digital on a per channel basis.
The Astro Saber and it's sister radio, the XTS3000 (an Astro Saber with a newly redesigned case), are inexpensive , maybe around $150-200 or so on eBay, will get you the P25 Digital modulation. You will need an old computer like a Windows XP 32-Bit operating system, the appropriate programming cables and a RIB. If the computer only has an USB port, you will need the USB to Serial Adapter cable to mate with the Motorola computer to RIB cable and have the Prolific driver installed on the computer.
