P25RX Alias page
White Bear, Mn.
Is there a trick to deleting multiple lines at once in the alias page? Highlight, Shift, Highlight does not work. I have to do them one at a time. Radio is working great, just fine tuning it matching radio IDs with squad numbers and such....
FreqNout
Chicagoland
I have all my RIDs in a csv file. Import csv button loads them. Any changes are done in csv file and import as needed.
wmlovell
Aurora, OH
I would like to be able to bulk delete rows, as well. The CSV file works but sometimes when I'm trying to update RIDs, I need to let it run for a while and then there are a bunch of unknowns that I'd like to purge while keeping other unknowns.
FreqNout
Chicagoland
If one deletes the RID in the alias tab or in the csv, it will show up again if the rig decodes the same RID. The alias tab is always adding the decoded RIDs to the list.
White Bear, Mn.
O.K. here is what I'm doing. I have been writing down Squad numbers and corresponding radio IDs at times so, I can add them to the alias page. I just did not want duplicates radio IDs under the ones I'm adding. So I unhook the antenna, add the ones I have then delete the ones under them one at a time. No big deal, we have long cold winters up here.
White Bear, Mn.
Like FreqNout said: The csv file is the best way to edit the alias. Even delete multiple rows at once and modify any data you would like, then import the csv file. It can be opened with Wordpad.
