Your diligence dedication and response is unheard of!!! I’d say keep it up but don’t want to jinx us. 😄. I’ll load it in a hour or so on both unitsI found it. I believe this issue is fixed in version 12-09_0713.
I put this on the two, one of them has a strange display now and not getting entries in the TG logI found it. I believe this issue is fixed in version 12-09_0713.
Yes, it was some logic that was messed up in a previous version on both the P25RX-II and the P25RX. I already had it fixed in the P25RX-II, so the fix for the P25RX would have found its way in there sooner or later. I don't think this change would have anything to do with the new problems you are having with patches.Was it doing anything beyond a message?
Not sure it matters, but the patch was between a P25 p1 system and a P2 system. I was listening to the P2 only.Yes, it was some logic that was messed up in a previous version on both the P25RX-II and the P25RX. I already had it fixed in the P25RX-II, so the fix for the P25RX would have found its way in there in the next big release. I don't think this change would have anything to do with the new problems you are having with patches.
When a grant for a patch is received, the only difference is that it is a different talk group id. As long as you have that id enabled, or you allow "unknown talkgroups", then it will be treated like any other talk group. It shouldn't matter if it is P1 or P2. Let me know if you continue to have issues with this. It might be difficult for me to track down until I get IQ file recording working for the P25RX. The local systems here don't do patches yet.Not sure it matters, but the patch was between a P25 p1 system and a P2 system. I was listening to the P2 only.
On the sds the TG showed as the same one I had enabled in my p25rx TG list, and the second the patch was enabled the grants stopped, the second they said they were killing it the audio grants for that TG started appearing on the P25rx. During the patch time the other two channels were getting utilized and were working. I can't enable unknown as there are thousands of PD channels and I only want the 2 local ones. One of which was the patched TG.When a grant for a patch is received, the only difference is that it is a different talk group id. As long as you have that id enabled, or you allow "unknown talkgroups", then it will be treated like any other talk group. It shouldn't matter if it is P1 or P2. Let me know if you continue to have issues with this. It might be difficult for me to track down until I get IQ file recording working for the P25RX. The local systems here don't do patches yet.
Do you have "allow unknown talk groups" on the P25RX enabled? During the patch time, the TG will be a "super group" with a different id. I don't know how the SDS100 handles it, but the P25RX does not currently keep track of what groups the "super group" is composed of. That may be why you are seeing something different for behavior. In other words, when a patched grant is received, multiple talk group ids are associated with a super-group id. The P25RX does not currently keep track of all this information. It only looks at the super-group id in the grant and treats that like any other grant.On the sds the TG showed as the same one I had enabled in my p25rx TG list, and the second the patch was enabled the grants stopped, the second they said they were killing it the audio grants started appearing on the P25rx. During the patch time the other two channels were getting utilized and were working.
[/QUOTE
No I do not have unknown talkgroups enabled, there are hundreds of PD channels and only want 2. East and West. West was patched to the neighboring town. They have ended the helo monitoring so I cannot check now. I am pretty sure that last week there was another helo operation and I was listening to it. I don't remember which radio was getting it. On the sds it just showed the local West TG ID. I only program the same 2 channels in the SDS.
I'll enable unknown, then go out and 'borrow' a car and cross city lines. they should send the bird after me, when I get out in 3-6 with good behavior I'll check the P25 to see what it shows. or maybe next time I hear it I will just enable and watch the log. It doesn't happen every day. ;-)I'll add that to the list of things to do. It probably should keep track of the sub-group ids and use that to determine if the super-group is enabled.
I thank you, my wife.. that remains to be seen... Downloading and testing now.Easy enough. 12-09_1316 should always pass patched talk groups (plus it will keep you out of trouble). I'll work on some other options later on. Seems like this would be a good default since a patched talk group implies something interesting happening.
For the TG logging issue, I recommend pressing the "edit" button on the TG Log tab. Enable all the log triggers. See if that fixes it for you.This version hung up on the reset to reload. the P25 is flashing fast but no activity on the screen.
edit - shut app down it is progressing with the load. Console Display still strange and not all granted logged in TG log but up and running.
Nope... the screen logging changed with the previous version.For the TG logging issue, I recommend pressing the "edit" button on the TG Log tab. Enable all the log triggers. See if that fixes it for you.
