P25T Encryption Issues
Gadgetmann
Actually I did not, I never got it to work. It would say Programming 1 keys, please wait for a while. I waited for an hour and it never programmed. I used PPS and import the .ekf file I made. Also, when making the .ekf file and after I put in the keys, when I clicked Generate, it changed the keys. I have tried it both with clicking Generate and leaving the keys as is after I entered them.
FishScan
In E8 do you have the encrypt key program box checked? Then you go to the pager menu, click on encrypt key program, then send the key?
Gadgetmann
Yes, in E8 the encrypt key is checked and not sure what you mean by "going to this in the pager menu" but I go in E6 Secure Menu and import the .ekf file I made and select and program that.
FishScan
You have to tell the pager its about to receive a key.
Gadgetmann
OMG !! it worked, tyvm for the help. Now I just have to do some programming and testing. I assume range/signal strength will affect reception/decryption? I am testing a county about 40-50 miles away and while I have good signal strength it will show the tg active but no audio, just a blurp initially of garbled audio then just a quiet hiss.
Phillipsc84
Fort Mill, SC
Let to the party but also there is an option under the "Function Status" menu (Option 8) of "Recv. Encrypt" which can be turned on and off. This setting is pretty obvious, but it toggles weather or not to receive encrypted calls. Just another thing to always double check.
Gadgetmann
Can I enter more than 1 set of keys? When I enter the one set for AES it shows up but also has Key001 and Key002.
1268
We are currently testing ADP encryption on older model "A" G4 pagers using PPS 4.0.46 and Firmware v2.04-T02B. After a few hours in the results look promising compared to the firmware we had back in December 2024.
Did you ever get this to fully resolve your issues with AES ?
Gadgetmann
Yes, working well for AES on P25 Phase I.
