PA STARNET
RES27CUE
Philly Metro,PA
I apologize in advance if this is already posted somewhere else and if it is i will close it out. I was wondering if anyone has had success monitoring the PA STARNET system. I know there is a bit of encryption for law enforcement but i am looking to monitor the non E stuff. I am looking to monitor in the western montgomery county area. Do you have to enter all the frequencies listed as the system in a scan or can I grab the closest to my area to monitor local stuff to me? TIA.
Whiskey3JMC
Quiet numbskulls I'm broadcasting!
Simulcastylvania, TE
Hey Drew:
Have a look at the RRDB entry. Anything mode "T" is clear. You won't be able to monitor everything systemwide on every site. If you're interested in PennDot, focus on District 6 talkgroups & if you have a scanner utilizing service types make sure "Public Works" (& anything else from "tag" column you're interested in) are turned on. You'll hear chatter occasionally throughout the day from road & tow crews but they're non-stop during major snow events. As of this posting I'm hearing some Montco PennDot chatter from Devault 800
Enter only the control channel frequencies for the sites within range to you. Devault VHF & 800, Willow Grove VHF, Belmont & a few others are within range to us. Have a look at the "County" column in Sites and Frequencies for a better idea of what may be within range
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
Depending on where you are in western Montco, you would want to target the following sites:
70 - Devault VHF
75 - Devault 800
80 - Graterford 800
135 - Geigertown 800 (havent had much luck seeing this site in most of western Montco)
148 - Gulph Mills 800
If you get to the far NW corner of the county, a couple of the Lehigh Valley sites may come into play:
84 - Emmaus 800
85 - Flint Hill VHF
On a scanner in a car, reception can be spotty if you don't have an external antenna, especially in the Pottstown area. That Geigertown site is really blocked by terrain in the direction of Pottstown, so even though it is fairly close, it just doesn't help all that much.
Whiskey3JMC
I've had past success from "West Montco" picking up certain Berks, Lehigh & Lancaster County sites from various roof antennas I used over the years
RES27CUE
Philly Metro,PA
Hey Drew:
Hi @Whiskey3JMC I mostly want to listen to district 6 road and tow crews. I am in the same area as you so I will try to add the ones you stated and get back to you with what I figure out thanks.
RES27CUE
Philly Metro,PA
70 - Devault VHF
75 - Devault 800
80 - Graterford 800
84 - Emmaus 800
85 - Flint Hill VHF
HI @HM1529 I'm really south central/east montco norristown,kop,plymouth areas I will try the ones you listed and get back to you on it thanks.
RES27CUE
Philly Metro,PA
I programmed it into my xg100 looks like gulph mills site is strongest for where I am, I was able to hear the safety trucks this morning. My only problem is I can't scan multi-site so I have to make different zones for different sites
csinq
PA
Are you able to pickup any traffic on the 800 sites? Wondering if I need VHF sites only. I am unable to even hear psp garbled on 800 sites.
