Pager write fail
swm239
Hello, I have been having a very difficult time as of late trying to read or program our minitor 5 pagers.
I am trying to read a pager, it gets half away across on screen and then light goes out on computer cord and I get a fail. I try a 2nd or 3rd time and it works. I make a couple of program adjustments and have not touched pager, or cords and then try to write back. It goes across 1/2 way on screen and then light goes out and get write failed. I wait a week and try again and same issue. Sometimes it will work on one pager, I put in a 2nd one and right back to same as above. I have switched com ports and get the same results.
I have switched to a 2nd laptop and getting the same thing. I contacted a neighboring Dept and borrowed their programming cup and cords and get the same results on both of our laptops. I am at a loss on why it will sometimes read it but wont write back or wont read it at all. Com ports are verified. Shows version 1.7.2
Has anyone else been seeing this and if so, have you figured out what was wrong? Thanks for any input,
Scott
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Scott
If you are getting the same error from different computers and different programming cradles cables, what else is always common? Wall wort maybe? Bad wall socket?
Also, download a new, clean copy of the PPS, preferably right off Motorola Solutions: http://www.motorolasolutions.com/content/dam/msi/software/pagers/m5-setup-1.7.2.zip BUT! Before you install the new one, uninstall whatever is on your laptop first.
Anybody else got any ideas?
