Eh, I'll post it up here in case anybody else is looking to get into it as well.
I'm still new to this so I'll share what I know. I'm still working out the kinks.
The frequency that I have listed above is, as I said, the frequency that PBCFR apparently sends out their pager tones. The tone is "encoded" (if you will,) in the POCSAG format.
Now, how do we decode this? There is a
program called PDW that is used to decode a variety or pager formats (POCSAG, FLEX, etc.) It can receive the signal in one of several ways.
The first, simplist, but probably least effective way is to run a 3.5mm audio cable from your scanner to your computer via line-in. The trouble with this is that you need to adjust your volume controls on both your scanner and your computer so that it is as high as it can go without clipping. Getting that sweet spot can be frustrating, but I've managed to do it. But like I said, it is very touchy. I have yet to get it just right on my Uniden BCD396-XT
The second method is to use a discriminator output of your scanner, if it has one. I believe what the discriminator does is essentially bypasses the analog audio output of the scanner, and just gives you the pure output. I think that may be a poor description, but I'm not 100% sure about how else I can describe it. Not very many scanners come with it I believe. Most of the time I think it is some wiring job that the owner has done to their scanner to give it that functionality.
You can also send the signal via serial / RS-232 cable if your scanner supports that, but I have not been able to get that to work on my Uniden BCD-396XT as of yet.
The third way that I know of (but have not tested yet,) is to get a software controlled radio that plugs into your computer via a software-controlled receiver. I happen to come across
this one that was listed on Amazon that I found on
this blog page talking about how to set it up with PDW. I am hoping that since there should be no analog distortion from an audio cable, that this will work great out of the box, but I will report back when I get it set up.
Hope that gives you a good brief intro into how to get started with this stuff. Believe me, there is plenty of Googling and reading to be done here. But once its set up right it can be pretty cool. The videos on that blog page show a good example of what it looks like when all properly setup.
