Palmetto 800 Missing Sites & Talkgroups
evan
South Carolina
The sites in the database is actually 77 the site called Columbia was removed by admin Brian as it was not being used for any voice comms but had an active control channels. I believed the control channel was 853.1125 .
Does anyone know the purpose of this site? It's been on the air for years. Is it for testing?
mrat1234
SC
I've been trying to figure that out also . Ive heard some key ups on Motorola talkgroups on the site last year but never heard any voice. It could be a site Motorola set up just for them.
mrat1234
SC
That list contains both primary and alternate control channels. Stand-alone ASRs typically have 2 control channels provisioned and simulcasts have 4. Pal8 puts out a list of 128 and 250 control channels to accommodate radios that have different CC capacities. Last I checked the system was supposed to come out to around 80 or so sites so 76 ID'd out of 80 isn't bad when they're still building the system out.
Thanks for that info i am currently monitoring a few sites i can receive in the Irmo area that are standalone and some frequencies marked as alternate are indeed used for voice and only have 2 control channels. Im going to try to analyze as many sites as i can before i make a submission.
brian
DB Administrator
South Carolina
So let me see if I can understand what you're saying, Noah. You received a copy of a control channel list from a Palmetto 800 radio. And it has a certain number of frequencies, so you're trying to correlate frequencies to sites?
As trumpetman indicated, that list ideally contains all active control and alternate control channels for all sites in the system, but not in any particular order. And the number of frequencies contained in the list is based on the memory capacity in the radio, which varies from model to model. So it's possible that some active CCs or ACs have been omitted to make the list "fit" into the radio. It's also possible that some frequencies are duplicated among two or more sites in the state - an alternate CC in Beaufort County might be reused on a site in Marlboro, for example. And there may be frequencies included in the list for sites that haven't come online yet. So, I'm not sure how you'll successfully match up all frequencies to sites and reach some conclusion about "missing sites."
Scanners offer no way to identify frequencies used as alternate CCs. The only way that information is determined is to monitor with one of control channel decoding applications. Pro96Com, Unitrunker and DSD+ are the most popular, but there are others. Not only will these programs show you frequency information, but they log talkgroup activity and show things like affiliations and de-affiliations, neighbor sites, and so forth. This is the type of tool I and others use to determine much of the data that's contained in the database regarding sites.
Maybe post information you're considering posting to the forum before you submit to the database.
mrat1234
SC
I understand that it doesn't mean there are 128 sites I was just saying I got a list and wanted to share it. Also on my submission I do verify the info before I submit. The talkgroups I submitted have been verified from an actual radio as indicated from my submission.
mrat1234
SC
I do see how my post is confusing. I meant to put maybe all the remaining sites control channels are in the list not 52 sites. obviously i dont think SC would build/need 128 sites.
jonwienke
More Info Coming Soon!
VA
Your list would be a lot more useful if it specified which control channel(s) were used by each site. If you have read access to a programmed radio, that should be easy.
mrat1234
SC
The radio did not have the list of site aliases complete filled out. All the list had were the Charleston county sites as that is where the radio is from.
mrat1234
SC
Here is a list. I had to use the database as the radio only had the names of the Charleston county sites.
852.35000 - Charleston Simulcast (County)
857.93750 - Charleston Simulcast (County)
858.48750 - Charleston Simulcast (County) , Marion County Simulcast
857.48750 - Charleston Simulcast (County)
854.41250 - Dorchester County Simulcast
854.38750 - North Augusta (Aiken County)
860.38750 - Canadys (Colleton County)
860.46250
859.38750 - Canadys (Colleton County)
858.76250 - Dorchester County Simulcast
853.77500
852.92500 - Long Mountain (Oconee County)
853.18750 - Summerville (Charleston County)
853.92500 - Orangeburg (Orangeburg County)
774.58125
774.83125
851.62500 - Johnston (Edgefield County)
851.82500 - Ravenel (Charleston County)
851.95000
851.96250 - Hogback Mountain (Greenville County)
852.17500
852.42500 - Spartanburg County Simulcast
852.47500
852.53750
852.57500 - Chester (Chester County) , Holly Hill (Orangeburg County) , Anderson County Simulcast
852.60000 - Anderson County Simulcast
852.61250 - Moncks Corner (Berkeley County)
852.62500 - Greenwood (Greenwood County)
852.67500 - Bennettsville (Marlboro County)
852.71250
852.86250 - Chester (Chester County)
852.87500 - Sandy Run (Calhoun County)
852.90000 - Joanna (Laurens County) , Lynchburg (Lee County)
852.93750 - Spartanburg County Simulcast
852.95000 - Manning (Clarendon County)
852.96250 - Anderson County Simulcast
853.03750
853.05000 - Spartanburg County Simulcast
853.07500 - Union (Union County) , Georgetown County Simulcast , Walterboro Simulcast (Colleton County)
853.10000 - Seneca (Oconee County) , Camden (Kershaw County)
853.12500 - Greenwood (Greenwood County) , Moncks Corner (Berkeley County)
853.15000 - Sandy Run (Calhoun County)
853.16250 - Anderson County Simulcast
853.17500 - Newberry (Newberry County)
853.20000
853.21250 - Kingstree (Willamsburg County)
853.23750 - Winnsboro (Fairfield County) , Bluffton (Beaufort County) , Georgetown County Simulcast
853.25000 - Barnwell (Barnwell County)
853.26250 - Greenville County Simulcast
853.27500 - North Myrtle Beach (Horry County) , Jasper (Jasper County) , Darlington (Darlington County)
853.28750 - Joanna (Laurens County)
853.31250
853.32500 - Russellville (Berkeley County)
853.35000 - Georgetown County Simulcast
853.36250 - Camden (Kershaw County)
853.40000 - Aiken (Aiken County)
853.41250 - North Kershaw (Kershaw County)
853.42500 - Orangeburg (Orangeburg County) , Thicketty (Cherokee County)
853.45000 - Union (Union County) , Edisto Island (Charleston County)
853.46250 - Caesars Head (Greenville County)
853.47500 - Newberry (Newberry County)
853.50000 - Lexington County Simulcast
853.51250 - Chappells (Newberry County) , North Charleston (Charleston County)
853.52500 - Conway (Horry County)
853.53750 - Greenville County Silmulcast , Dillion (Dillion County)
853.56250 - Walterboro Simulcast (Colleton County)
853.60000 - Pickens (Pickens County)
853.61250 - Lynchburg (Lee County)
853.62500 - Hogback Mountain (Greenville County)
853.66250 - Winnsboro (Fairfield County) , Russellville (Berkeley County)
853.67500
853.68750 - Barnwell (Barnwell County) , Georgetown County Simulcast
853.70000 - Spartanburg County Simulcast
853.71250 - Manning (Clarendon County) , Newberry (Newberry County) , North Myrtle Beach (Horry County)
853.73750 - Aiken (Aiken County)
853.75000 - Yemassee (Hampton County) , Greenville County Simulcast
853.78750 - Holly Hill (Orangeburg County)
853.80000 - Caesars Head (Greenville County) , Properity (Newberry County) , Darlington (Darlington County)
853.81250 - Bamberg (Bamberg County) , Port Royal (Beaufort County)
853.83750 - Kingstree (Willamsburg County)
853.86250 - Greenville County Simulcast , Conway (Horry County) , Jasper (Jasper County)
853.90000 - Joanna (Laurens County)
853.91250 - North Kershaw (Kershaw County) , Edisto Island (Charleston County)
853.95000 - Summerville (Charleston County) , Chappells (Newberry County) , Chesterfield (Chesterfield County)
853.96250 - Seneca (Oconee County) , Robertville (Hampton County)
853.98750
854.73750 - Augusta (Richmond County)
854.86250 - McBean (Richmond County)
855.03750 - Due West (Abbevile County)
855.31250 - North Augusta (Aiken County)
855.43750 - Augusta (Richmond County)
855.46250 - Lexington County Simulcast
855.51250 - Due West (Abbevile County)
855.63750 - Blythe (Richmond County)
855.66250 - North Augusta (Aiken County)
855.78750 - McBean (Richmond County)
856.33750 - Blythe (Richmond County)
856.46250 - Sumter County Simulcast
856.48750 - Harbison (Richland County)
856.58750 - Beaufort County Simulcast
856.68750 - Beaufort County Simulcast
856.86250 - Yemassee (Hampton County)
856.91250 - Plum Branch (McCormick County)
857.21250 - Beaufort County Simulcast
857.26250
857.43750 - Beaufort County Simulcast
857.46250 - Sumter County Simulcast
857.91250 - Plum Branch (McCormick County)
858.26250
858.28750
858.46250 - Sumter County Simulcast
858.68750 - Harbison (Richland County)
858.71250 - Charleston Simulcast (State)
858.83750 - Sally (Orangeburg County) , Charleston Simulcast (State)
858.93750
858.96250
859.26250 - Lexington County Simulcast , Florence County Simulcast
859.46250 - Sumter County Simulcast
859.48750 - Marion County Simulcast
859.68750 - Florence County Simulcast
859.83750 - Sally (Orangeburg County)
859.86250
859.88750 - Johnston (Edgefield County)
860.23750
860.48750
860.73750
860.93750
856.93750
mrat1234
SC
I just spoke to the guy i bought the xts5000 from he let me read another one he had and it had the same list. I was able to some what identify a missing site in the Charleston area. All the info i have is the site id is RFSS:1 (1) and a Site ID: 66 (42) or 65 (41). I believe the site is called Andrews and located in the middle of Georgetown and Williamsburg counties. Any frequency or license info is unknown.
brian
DB Administrator
South Carolina
I was just in the Grand Strand area recently, and I passed through Andrews on my way. Although the Georgetown County Simulcast site (1-22) doesn't appear to have a sub-site in Andrews, which is on the west edge of Georgetown County, the site covers very well there and I was able to monitor the site with my mobile set-up pretty far into Williamsburg County. It is certainly true that one can find some areas of fringe coverage in the rural areas of Williamsburg County.
Also, here's the neighbor list for the Georgetown County site as reported by DSD+:
Neighbor: BEE00.1D9-1.6 ; Berkeley County Simulcast
Neighbor: BEE00.1D9-1.8 ; Moncks Corner
Neighbor: BEE00.1D9-1.21 ; Florence County Simulcast
Neighbor: BEE00.1D9-1.47 ; Russellville
Neighbor: BEE00.1D9-1.53 ; Conway
Neighbor: BEE00.1D9-1.54 ; North Myrtle Beach
Neighbor: BEE00.1D9-1.55 ; Kingstree
Neighbor: BEE00.1D9-1.56 ; Brittons Neck
Neighbor: BEE00.1D9-1.58 ; Awendaw
So there's no Site 65 or 66 on the air yet that's tied to the system core. It's possible that this is a site planned for the future that will be installed as funding allows.
Performing a range search of FCC licenses within 4 miles of Andrews also does not reveal any likely Palmetto 800 licensees.
