INDY72
What type of scanner?
Sent from my LG-K330 using Tapatalk
I just posted a few talkgroups for Aiken County.
If anyone can confirm additional talkgroups for SCHP Troop 7, Augusta-Richmond County, Bamberg Co (they might be all conventional still), Orangeburg County, and Aiken County, that will be very helpful.
We have most of the Troop 7 sites identified, but it's always helpful to get confirmation that the active control channel frequencies are accurately indicated.
As others have indicated, it is probably reasonable to assume that Aiken County talkgroups are in the 20500-20999 range. Augusta-Richmond County is probably in the 55000-55499 range.
Brian here are TGIDs that I heard this morning:
- 20505 - Aiken County Sheriff (Possibly Warrants - Civil Paper Servers)
- 28501 - Transportation - Possibly Best Friends Express
- 28503 - Transportation - Possibly Best Friends Express
I heard no information to confirm that the 28501 & 03 are Best Friends Express, but they were discussing pick ups and drop offs.
Gary
Shutter_Bug51
Time to start logging the Site ID, RFSS and talkgroups....
Highway Patrol Troop 6 + Holly Hill – June 19-23, 2017.
(Jasper, Beaufort, Colleton, Dorchester, Charleston, Berkeley)
Highway Patrol Troop 5 + Chesterfield – June 26-30, 2017.
(Williamsburg, Georgetown, Horry, Marion, Florence Dillon, Marlboro, Darlington, Chesterfield)
Master-Site Reconfiguration – July 2-21, 2017
Highway Patrol Troop 7 + Augusta, GA – July 31-August 4, 2017
(Orangeburg, Calhoun, Bamberg, Allendale, Hampton, Barnwell, Aiken)
Highway Patrol Troop 1 + Sandy Run – August 14-18, 2017.
(Lexington, Richland, Kershaw, Lee, Sumter, Clarendon)
Highway Patrol Troop 2 – August 28-September 1, 2017.
(Newberry, Laurens, Saluda, Edgefield, McCormick, Greenwood, Abbeville)
Highway Patrol Troop 4 – September 11-15, 2017.
(Lancaster, York, Chester, Chesterfield, Fairfield)
Highway Patrol Troop 3 + Cherokee – September 25-29, 2017.
(Spartanburg, Greenville, Anderson, Pickens, Oconee, Cherokee)
http://www.masc.sc/SiteCollectionDocuments/Risk Management/P-25 Letter 03-07-17.pdf
As for all yes the entire system is converting to p25. Not just tg. The ENTIRE SYSTEM. The current Palmetto 800 is analog based with digital tgs on it. This is upgrading to completely digital.which highway patrol troop would union be under troop 3 or 4 and are all the palmetto 800 talkgroups switching to p25 for all counties
Does anyone know if adding both site frequencies from the new P25 and Palm 800 sites for one individual site will make any difference in the amount of tgid's one could pickup?
Ex. Sumter site frequencies from the P25 and the 800 sites added into one P25 system.
To properly answer here: These are 2 separate systems and MUST be set up as such. When you set up the system type it will treat ALL sites programmed as that type for that system! Only in the oldest P25 scanners like the PRO-96 did you not set a system up as Mot and it also covered P25. Newer scanners don't work that way. With the exception of maybe the Uniden BCDX96T family? The XT ones you would set P25 standard for the new system and MOT for the Legacy Palmetto 800. But all scanners will only use the cc they find for the site programmed first. If it finds an legacy cc it will track the legacy system. If it finds P25 it tracks that. That is why you never put both in same system if they are standing both up side by side.It depends on how your scanner is programmed and how it handles selecting control channels. With the PRO-106 "family" of scanners, you can choose ROAM or STAT and that will determine whether the scanner picks the "best" control channel and sticks with it, or scans each active site during each pass. The PSR-800 family of scanners only have a "Roam" setting and attempts to pick the "best" control channel and stick with it. Programming each site as a separate system can mimic the "STAT" setting.
Other radios handle control channel/site selection differently.
Milf....I think another notation that's needs to be added to the database is the County Simulcasts (as part of the State core) vs the actual state system carry different talkgroups. I can predict that a lot of people are going to have issues if they just download all sites from Sentinel or EZScan and try to monitor SCHP even in the County they are in. I've brought this up before that in Charleston for example, there are two separate cells (one County and one State) all part of the State core. So if you program in both and the scanner locks on that control channel for County you will not hear SCHP...you will have to build two separate Palmetto P25 systems in your scanner. So knowing what sites carry what traffic may be helpful.
