PCWIN Tucson
tlefkowitz
Hi All
Can anyone tell me if all voice on Tucson PCWIN system is encrypted?
Todd
JPSan
Tucson, AZ
It's a Motorola P25 Phase II system and essentially UNencrypted system county wide.
So, it will require a newer digital scanner. In case you don't have one here is what is available.
Uniden : BCD436HP, BCD536HP, BCD996P2 and Home Patrol 2
Whistler : WS1080, WS1095
GRE : PSR 800
Radio Shack : Pro 668
DanRollman
Atlanta, GA
Hi All
Todd
Few PCWIN talkgroups are encrypted. It is mostly "in the clear," although today's crappy consumer-grade digital scanners (around $500) have trouble receiving simulcast Phase II systems (PCWIN) very clearly, so you'll want to moderate your expectations in terms of signal clarity.
For reliable and clear digital decoding, you'd need to use a (much) more expensive commercial Phase II radio that is capable of being programmed as a true receive-only (e.g. does not try to affiliate with the system) radio like the Relm BK KNG-P800, which will run you close to $2,000 but sounds absolutely terrific on PCWIN.
Dan
tlefkowitz
Thanks, Dan
I appreciate your informative comments..I think I'll hold on to my $$$ for a while :)
Todd
KB7MIB
Peoria, AZ.
Isn't Uniden's BCD325P2 handheld also Phase II capable? It's the handheld version of the BCD996P2.
John
Peoria
AZScanner
Somewhere in this room. Right now, you're very col
Don't forget about OP25! I'm using it to monitor PCWIN and the decode quality puts my 436HP to absolute shame. If you've got a spare computer you don't mind having Linux on (or you can dual boot) and $75-$50 you can spend on a decent SDR dongle, you can monitor PCWIN flawlessly with OP25. I love it because it has given me a second phase 2 capable "scanner" for less than the price of most analog units, (not counting the cost of the dedicated computer I've purchased for it ;)).
-AZ
tlefkowitz
OP25
As a matter of fact, I have bought an SSD for my Win7 PC and will install Linux on it in prparation for OP25
Thx
Todd
kd7eir
Tucson, AZ
OP25/GNURadio runs quite well on a Raspberry Pi 2 with the Jessie release of Debian, making it even cheaper to use.
verhoffj1
Lakewood Washington
RELM/BK KNG-P800
Dan
So how is the programming for the RELM/BK KNG-P800 and where do you suggest I buy one at? My Area is using Project 25 Phase II TDMA modulation. Any feedback would be appreciated.
waynedc
Vail, Arizona
KNG-P800 available...
If anyone in AZ is interested in a BK KNG-P800 with all accessories, please let me know. I can provide some programming for the RWC/TOPAZ or PCWIN systems as needed. The programming cable will need to be purchased separately.
