PG&E Wide Area MPT-1327 System - Post your findings here!
kma371
454.15 b0c1
adjacents
id 5089 ch 168
id 50b1 ch 170
id 50d9 ch 169
id 50f9 ch 197
im picking up 50c1 on 3 freqs, 454.15, 454.14375 and 454.1375, dunno which is true freq
kma371
This is too cool, first time i ever decoded anything,lol, So is all this im hearing PG&E?
theres tons of other data signals you can decode besides this type. scan around for trunked systems. those are the best to decode. or TRBO signals.
inigo88
California DB Admin
San Diego, CA
Hope all this is usefull, i did a limit search from 430.0 to 490.0 for all info given here, from my home location. Is there anything more in trunkview i can set to help better id anything?
That was very helpful! Thank you! The only other thing we could do is try to narrow down where some of the 454 MHz sites are based on where you're located in Butte county and how strong your reception of each site is.
454.1000 is my strongest, let me work on this, every now and then i hear what sounds like morse code, any ideas?
inigo88
California DB Admin
San Diego, CA
The morse code is the FCC license identifier (should happen every hour or so). This is the easiest way to figure out FCC data (if you happen to know morse code, unfortunately I do not :) ).
Freq Bars Signal strength
454.1000 3 solid 560 to 570
454.4875 2 solid 530 to 540
454.5000 1 tickling 2 450 to 460
464.0875 2 solid 460 to 470
454.5625 1 some static 370 to 380
using tune mode on win500 for numbers
DSheirer
Fulton, NY
If it helps in solving your puzzle ... the MPT-1327 control channel identifier is made up of a 15-bit field that tells you the network, zone, tower and access label. You can find a description of these in the MPT1327 spec.:
5081 = 1 01 00001 0000 001 = Network #2, Zone #2, Tower #1
5091 = 1 01 00001 0010 001 = Network #2, Zone #2, Tower #3
50A9 = 1 01 00001 0101 001 = Network #2, Zone #2, Tower #6
50B1 = 1 01 00001 0110 001 = Network #2, Zone #2, Tower #7
50C1 = 1 01 00001 1000 001 = Network #2, Zone #2, Tower #9
50D1 = 1 01 00001 1010 001 = Network #2, Zone #2, Tower #11
50D9 = 1 01 00001 1011 001 = Network #2, Zone #2, Tower #12
50E1 = 1 01 00001 1100 001 = Network #2, Zone #2, Tower #13
50F9 = 1 01 00001 1111 001 = Network #2, Zone #2, Tower #16
5109 = 1 01 00010 0001 001 = Network #2, Zone #3, Tower #2
5111 = 1 01 00010 0010 001 = Network #2, Zone #3, Tower #3
5119 = 1 01 00010 0011 001 = Network #2, Zone #3, Tower #4
5399 = 1 01 00111 0011 001 = Network #2, Zone #8, Tower #4
53A9 = 1 01 00111 0101 001 = Network #2, Zone #8, Tower #6
54B9 = 1 01 01001 0111 001 = Network #2, Zone #10, Tower #8
54C1 = 1 01 01001 1000 001 = Network #2, Zone #10, Tower #9
54E1 = 1 01 01001 1100 001 = Network #2, Zone #10, Tower #13
5631 = 1 01 01100 0110 001 = Network #2, Zone #13, Tower #7
Denny
inigo88
California DB Admin
San Diego, CA
Denny
Outstanding Denny, thank you! As you can see I don't know MPT-1327 very well and am kind of learning as I go with TrunkView (not many of these systems in California!).
I believe we just confirmed 50B1 as Mt Tamalpais in Marin County. Would that work with the location of your receiver Bill? Also according to the license, 5081 could be located at the Petaluma sub-station and not Sonoma Mountain, but Sonoma Mountain seems more likely due to the signal strength.
Breaking everything into zones:
Zone 2 - North SF Bay Area:
5081 = 1 01 00001 0000 001 = Network #2, Zone #2, Tower #1 -- Petaluma Sub-Station/Sonoma Mtn
5089 = 1 01 00001 0001 001 = Network #2, Zone #2, Tower #2
50B1 = 1 01 00001 0110 001 = Network #2, Zone #2, Tower #7 -- Mt Tamalpais
Zone 3: Possibly another sector of the bay area, or central valley.
Zone 8: Butte County / Northern Central Valley
53B1 = 1 01 00111 0110 001 = Network #2, Zone #8, Tower #7
(One of those is probably Sutter Buttes, since one of the old PG&E 800 MHz LTR sites was there.)
Zone 9: Western Sierra?
5411 = 1 01 01000 0010 001 = Network #2, Zone #9, Tower #3 -- Osborne Hill (Grass Valley)
Zone 10:
Zone 13: Northern coast? (Only seen as neighbor of Sonoma county site)
kma371
my remote receiver is in San Leandro so Mt Tam does come in well but I can't be positive.
I'll try the central valley stuff Sunday afternoon and see what I get.
I let trunkview run for few hours, and this is some of the log for Freq 454.1000.
12:33:41 - GTC | Go To Channel - Voice | (001) Org: 421 Tar: 6743
| Ch: 180 Freq: 1.12500 MHz |
12:33:43 - GTC | Go To Channel - Voice | (001) Org: 421 Tar: 6743
12:33:53 - GTC | Go To Channel - Voice | (001) Org: 421 Tar: 6743
12:36:56 - ACK | General acknowledgement | (000) Org: 2969 Tar: Registration ident
12:49:33 - GTC | Go To Channel - Voice | (001) Org: 421 Tar: 6743
| Ch: 189 Freq: 1.18125 MHz |
12:49:34 - GTC | Go To Channel - Voice | (001) Org: 421 Tar: 6743
12:49:44 - GTC | Go To Channel - Voice | (001) Org: 421 Tar: 6743
kma371
system 5391
454.0875
adjacent sites:
id 5389 ch 312
id 53b9 ch 378
id 53d1 ch 194
id 53d9 ch 199
id 5431 ch 200
system 5431
454.49375
adjacent sites
id 53d9 ch 199
id 53e1 ch 198
id 5391 ch 168
real weak copy
system 5099
454.55625
adjacent sites
none
even weaker copy
inigo88
California DB Admin
San Diego, CA
Woohoo voice activity!
I believe Org is the originating radio ID, while Tar is the target group (or radio) ID. The (001) is the MPT1327 prefix (sort of like the first number of an LTR talkgroup). If I'm reading this right, radio ID 1-421 is transmitting on talkgroup 1-6743. Also keep an eye out for two voice frequencies (Ch 180 and Ch 189).
From the adjacent site list for the other site 54B9, it looks like the control channel on 454.1000 on site 53A9 is Ch 168. The formulas are:
Current Freq = Base Freq + (Ch # * Step Size)
so to find the base frequency...
Base Freq = Current Freq - (Ch # * Step Size)
We know 454.10 = Ch 168, but the system could use 12.5 KHz steps or 6.25 KHz steps.
If it uses 6.25 KHz steps:
Base Freq = 454.10 - (168*0.00625) = 453.05
Then Ch 180 would be 453.05 + (180*0.00625) = 454.17500
and Ch 189 would be 453.05 + (189*0.00625) = 454.23125
Or if it uses 12.5 KHz steps:
Base Freq = 454.10 - (168*0.0125) = 452.0000
Then Ch 180 would be 452.00 + (180*0.0125) = 454.2500
and Ch 189 would be 452.00 + (189*0.0125) = 454.3625
What this all means, is that if you wouldn't mind plugging in 454.175, 454.23125, 454.25 and 454.3625 into a scan list for a while, we can figure out which step size they're using and thus the custom bandplan for the site. MPT1327 voice channels can apparently be identified pretty easily because there is a digital sounding databurst at the beginning and end of every transmission.
The bad news is, I'm pretty sure there will be a different custom bandplan for almost every one of these sites... so we're going to have to figure out a lot of them. :(
Im loading those freqs now, ill turn the hit list on for them, I was wondering on trunkview what i should have for a base freq?
454.2500 i have captured the 196.6 ctcss, with occasional data burst and what im guessing is the morse code FCC ID. no voice activity yet
is there something i can run to try to capture the morse code to get some FCC id's? i setup win500 to record audio and hit counts on the base and 4 freqs mentioned above, this will run 24/7 for awhile.
Soledad, CA
454.5750 I notice the pl change from 196.6 to 100.0
FYI it was real weak no bars
ID 50A1:
ID: 5089 Ch: 168
ID: 50F9 Ch: 197
ID: 5189 Ch: 436
ID: 5199 Ch: 197
ID: 53F9 Ch: 202\
This one was coming in full bars
461.8000 pl 196.6
ID 51B9:
ID: 5191 Ch: 356
ID: 51B1 Ch: 442
ID: 51D1 Ch: 084
464.08750 pl 196.6
- ID 5189:
ID: 50A1 Ch: 204
ID: 50E9 Ch: 171
ID: 5199 Ch: 197
464.16250 pl 196.6
- ID 51B1:
ID: 50A1 Ch: 204
ID: 5189 Ch: 436
ID: 5199 Ch: 197
ID: 51B9 Ch: 306
PG & E had the most disjointed radio system for a large company, especially utility company, that I've ever seen. Low band, VHF High and UHF depending on locations and within short distances of each other. Weren't the two functions, gas and electric, on different frequencies as well? I was in Livermore visiting my sister some years ago when the power went off in the middle of the summer during thunderstorm activity (read hot and humid) and had a bit of a challenge finding a frequency to listen to the activity on. I lucked out and found it within 5 minutes.
With this new service area wide trunked system will PG & E have a centralized dispatch system or did they already have that? This will be an interesting system to figure out.
