Firemantincan
- Joined
- Feb 21, 2017
- Messages
- 79
- Reaction score
- 15
TGID 1133 seems to be 8A2 (possibly) but it is not listed in the RRDB. It's been in use for a long time. Does the DB not get updated often or is this a bad id?
So 1133 and 1137 are not used any longer or did 8A1 and 8C1 move to the lower TG numbers? I seeing 1151 as AVD also I guess that is 8C2?Ok mystery solved 8A1 was simulcast to 8C1. The county has since changed that,8A1( is strictly Northside units. And the TG marked as AVD is the same as 8A2, but I am guessing that since it is bo longer a dispatch channel,they wanted that to reflect on the TG tag.
| 1133 | 46d | T | PGFD 8A1 Ops 1 | 8A1 Ops 1 ??? | Fire-Tac |
| 1135 | 46f | T | PGFD AVD | 8A2 Dispatch AVD | Fire Dispatch |
| 1137 | ???? | ||||
| 1151 | 47f | D | PGFD 8A2 Disp | 8A2 Dispatch 8C2 ?? | Fire Dispatch |
| 1153 | 481 | D | PGFD 8A1 Ops 1 | 8A1 Ops 1 (North) | Fire-Tac |
| 1155 | 483 | D | PGFD 8C1 Ops 2 | 8C1 Ops 2 (South) |
1133 is 8A1. 1153 is also 8A1. There are also three TGIDs for 8A2 (1151,1135, and 1137).
I have a feeling that we may be seeing 8A1 (1153), 8B1 (1133), and 8A2, 8B2, and 8C2 here. I would have to use one of the radios to figure that out though.
Yes, I have noticed this too. They have been doing this since COVID started I believe.So from what can tell ,for whatever reason the channels are still patched together. Now B11 is the ems coordinator channel ie " the these are the hospitals you can go to Channel". That Channel is only in service 0700-2300.
Yes.8A1: 8=MWCOG county designation; A=Zone (North division specifically); 1=channel selector position. The same schema applies to other channels. The ABC switch does change between Zones A, B and C, but there are additional Zones selectable by the front keypad. Channel selector positions 1,2, and 16 are the same endpoint throughout all zones (except special events zone.) Ops 1 and Dispatch channel selector positions were swapped several years ago so that members could reach a live operator by rotating the channel selector knob all the way in either direction.
