Air490
Can someone please explain the difference between APCO 25 Phase 1 and Phase 2.
rfmobile said:Phase 1 is a narrow band FM signal called "C4FM" that fits in a 12.5 khz spaced channel.
Phase 2 includes several proposed methods for improving bandwidth efficiency over phase 1. The most common is CQPSK - the signal is very similar to C4FM but fits inside a 6.25 khz spaced channel. There are other proposals including TDMA but CQPSK is the only form of Phase II actually implemented out in the field (that I know of).
If your FCC license resides in a portion of the RF spectrum that is expected to be re-farmed or re-spaced to 6.25 khz wide channels then you want Phase 2, otherwise you can get by with Phase I equipment.
-rick
N_Jay said:I do not know of any 6.25 FDMA solutions on the market.
CQPSK is used to enhance the separation of simulcast site at 12.5 kHz.
chrisjz said:M/A-COM OpenSky is currently the only APCO 25 Phase-II compliant system available on the market.
http://www.opensky.com/
Consider the following in regard to OpenSky:chrisjz said:M/A-COM OpenSky is currently the only APCO 25 Phase-II compliant system available on the market.
safetyobc said:I have a question about phase 1 and 2. Will the new BCD346T be able to track phase II if it is put in place in my area. My area is going digital at the end of 2005 or 2006. I plan on getting the 346. I have seen some scanners say phase 1 only?
Holy smokes!chrisjz said:M/A-COM OpenSky is currently the only APCO 25 Phase-II compliant system available on the market.
safetyobc said:i agree you couldn't sell the scanner. But is there a way to update the scanner with a download that would keep it current so we could get at least for a couple of years of use out of it before it is outdated. It is going to get expensive for us po folk to keep up.
N_Jay said:This method would be even more expensive, as they would have build in a lot of hardware and extra procesing power, since they would not know what job it would need to do when the standard cames out.
rfmobile said:N_Jay said:This method would be even more expensive, as they would have build in a lot of hardware and extra procesing power, since they would not know what job it would need to do when the standard cames out.
Actually ... for receivers that support multiple modes ... like AM, wide-FM, narrow FM, USB, LSW ... this could result in a design simplication and cost savings in production. They'd have to make some assumptions or compromises in terms of maximum bandwidth of the type of signal to receive.
Instead of having an AM detector, narrow and wide FM discriminators, and SBB detectors ... all of this circuitry could be replaced with a IQ receiver that down-converts to baseband plus a pair of A/D converters to feed the raw "I" and "Q" signals in digital form into a small processor. From that point on its just a matter of having the right firmware running inside the radio.
-rick
N_Jay said:Today they don't have all these circuits UNLESS that is the least expensive wauy to do the job.
Adding any costs to a product on the hope that it will meet a future undefined requirement is somthing that is rarely to NEVER done in product design.
If you have EXPERIANCE that disagrees with this, I would love to hear about it!
N_Jay said:But trying to plan enough expandabilty into a product to "flash" a yet developed protocol would be very risky.
In the end you would just as likely end up with a product carrying excessive costs that never are leveraged.
As I said, "If you have EXPERIANCE that disagrees with this, I would love to hear about it!" Meaning, if YOU have any PRODUCT DESIGN/DEFINITION experiance that is different, lets hear about it.
