Phase 2 ?
airbear21200
SE NC
So, on Monday, October 3, 2025, Brunswick County switched over to phase 2 on VIPER. My G5 pager is picking up all traffic normally, but my SDS100 and SDS200 are not. They will pick up the HP and Columbus county channels, but they have not gone phase 2 yet. I'm not seeing anything in Sentenal that requires a phase 2 setting. Am I missing something?
Whiskey3JMC
Just another pesky scannist
Simulcastylvania, TE
Are the Brunswick County talkgroups programmed in & applicable service types (reference "tag" column in the RRDB turned on?
Also these talkgroups are fully encrypted so you won't be able to track them
55041580DEBrunCo NarcLaw NarcoticsLaw Tac
55051581DEBrunCo Law TLaw Sheriff Talk-AroundLaw Talk
55061582DEBrunCo Sp OpSpecial OperationsLaw Tac
airbear21200
SE NC
They are all on. I did not change any settings and everything was working fine until the cut over at 8am Monday. I am aware of the encrypted talk groups. Thanks.
KE4ZNR
Radio Guru
You don't need any programming changes from Phase 1 FDMA to Phase 2 TDMA on VIPER.
Same Talkgroup IDs just TDMA instead of FDMA. I would make sure "TDMA Slot" is one of the options featured somewhere on your displays as it will tell you when TDMA Slots 1/2 are being used on a VIPER TG. Just an easy way to distinguish between FDMA/TDMA.
AA4BK
Central North Carolina
SDSxxx and BCDxxxHP scanners all handle P25 Phase 2 just fine. The only thing related to Phase 2 they don't handle yet is Phase 2 control channels, but I'm not aware of any Phase 2 control channels being used yet. Hopefully before that happens Uniden will get it together and release an update to support that.
airbear21200
SE NC
I'm not sure what the difference was, but I took my VIPER systems out of my favorite list and reloaded them from an updated master list. Seems to be working fine now on both my 100 and 200. Thanks for the help guys.
tvengr
Well Known Member
Baltimore County, MD
It is possible that the control channel frequency changed when they switched to Phase 2. You may have been missing a control channel capable frequency or it was avoided. The Site NAC possibly changed also. The SDS scanners can use Site NAC if programmed to do so.
