scannerloser
im a loser, baby.
Hey there,
I created a dedicated channel to my RTL-SDR setup that monitors the Phoenix, AZ Police in addition to surrounding areas. It's in stereo to allow mulitple conversations at one time, and I was wondering what comments, suggestions, or criticisms anyone had on it? Currently it's a display capture from my machine running SDRtrunk, but I'm totally open to changing the layouts or adding things to make it more fun or easier to understand. Whenever I "do work" on the setup or filters, I leave it running so people can watch.
** If I'm not supposed to post the link here, I apologize.. but it seemed like it was ok based on the description of the Forum. **
Primary YouTube Channel:
I'm not posting the actual URL for the stream itself, because I believe YouTube has a max of 260 hours(!) (or I just happened to drop offline after that amount of time) - Either way, the URL is likely to change from time to time, but I like being able to use my YouTube channel when I can't use the Broadcastify or other scanner apps, which has happened enough times that I created this
Cheers!
-SCANNERLOSER
Cheers!
-SCANNERLOSER
