Hi Bill,
The PBX system is Avaya with about 24 lines going out to each phone in rooms in the house, 4 TelCo lines coming in. The Demarc is inside the equipment room, the lines come in through underground conduit and there is no other Demarc on the outside. This was done for security. Whoever installed the Demarc ran a ground wire but never hooked it up, it was just hanging. I ran a new #6 copper to the ground bus in the panel.
The 4 lines come from the Demarc then into a ITW SurgeGate, this was then attached to a ITW outlet strip and plugged into the wall outlet, it does have a 3 wire plug but I ran a separate ground wire from the SurgeGate to the ground bus. Then I plugged the ITW outlet strip into an APC battery backup/surge protector.
Now I plan to add 4 lightning protectors from the company I linked to above in between the Demarc and the SurgeGate for extra protection with a a separate ground wire for them also.
So since you're a PBX tech, I'd like to ask you a couple of questions on this setup...
1- What's your opinion on the lightning protectors at the site I linked to ?
2- Is there anything else you would recommend ?
Please consider we're in central Florida and we get some major lightning storms pretty regular around here.
Thanks,
Steve
