Pi Image SDRTrunk SSH
PtBreak
I can't get my Pi Screen Connect to work, however I can connect with SSH and won't have access to my Pi for a few days to plug it into a monitor.
So my question is does anyone know the file path and command line to launch SDRTrunk via SSH for the Broadcastify Pi Image?
I can't remember the folder location for SDRTrunk however I'm currently running the latest Broadcastify Pi Image.
BinaryMode
2600 dialtone blvd
Wouldn't the ls (LS) command help find the location?
The command line to launch SDRTrunk is probably documented at the Github Repo.
In lieu of ScreenConnect, you may just want to use the VNC protocol, or rather the RFB (Remote Frame Buffer) protocol. It's like the malware/haxxer/privacy invasion software of Anydesk or TeamViewer without said malware/haxxer/privacy invasion. Take it up a notch and you can remote in external to your WAN via ZeroTier. ZeroTier does have an Android App and maybe one for iOS.
IF you have a router that's capable of being flashed to the third party firmware DD-WRT- OpenWRT, ASUS Merlin (pronounced Ah-Seus. I saw the commercial), etc you can use OpenVPN or Wireguard and connect into your LAN external of your WAN that way as well.
I use OPNsense so if I ever need full on port forwarding I do so on an IP address per IP address basis. Port knocking would be more ideal though.
PtBreak
Thanks guys I ended up getting it resolved a couple days later guess the pi just froze up
