PL or DPL Tones
BryanTheRed
Ø
NC
I need to find the pl or DPL (which ever it may be) for the following freqs!
453.05000 458.05000
453.30000 458.30000
453.60000 458.60000
453.90000 458.90000
CCHLLM
And in what location would these freqs be used? Or am I missing something obvious? Right of the top of my head I can think of at least 3 PLs for three of those, and at least 1 DPL, but they're all in different locations.
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
I believe 100.0 Hz is the PL tone used on the repeater output for the 3 PD and 1 Fire channels.
It is likely that 100.0 would be atleast one of the input tones on those repeaters, but that's NOT a certainty. Sometimes an agency will use a different tone on input if there have been problems with tropo interference in the past.
Some agencies will also use multiple input tones. When multiple repeater sites are in place, assigning each its own input tone can be used as a method for voting receivers.
Some agencies will also use an input (or output) frequency for simplex tac purposes, and the tac channel will have a separate tone.
Unless you have access to an "inside" source or programming template, some monitoring will probably be necessary to confirm input tones.
Jeff Multer
CommRX
Eastern NC
Some Greenville, NC 450's
453.05000-Greenville Fire / Rescue / E.M.S. Dispatch (458.050) PL 100.0
453.11250-Greenville Local Government
453.20000-Greenville Public Works - Garbage Disposal
453.30000-Greenville Police - Ch. 1 (458.300) PL 100.0
453.33750-Pitt Community College
453.45000-Greenville Police PL 100.0
453.50000-City of Greenville
453.60000-Greenville Police - Ch. 2 (458.600) PL 100.0
453.72500-ECU Police / Traffic Services
453.75000-Greenville Housing Authority Base / Repeater
453.77500-Pitt Area Transit System
453.90000-Greenville Police - Ch. 4 (458.900) PL 100.0
453.92500-ECU Campus Maintenance PL 123.0
453.95000-Greenville Fire / Rescue
453.96250-Greenville Rescue E.M.S. / 911 Dispatch
454.11250-Pitt Area Transit System
454.21250-Greenville Police
454.22500-ECU
454.81250-Greenville Police
454.83750-ECU Campus Maintenance
456.75000-Greenville Housing Authority
458.05000-Greenville Local Government (453.050)
458.20000-Greenville Local Government
458.30000-Greenville Local Government (453.300)
458.45000-Greenville Local Government
458.60000-Greenville Local Government (453.600)
458.75000-Greenville Housing Authority Mobile Radios
458.80000-Grifton Police (453.800)
458.86250-Greenville Fire Scenes - Ch. 1
458.90000-Greenville Local Government (453.900)
459.22500-ECU
I can't comment on the 458 freqs. as I usually don't receive them.
jeffmulter
To use an example in your area, JVRS, N.C. Forestry runs their district 4 repeater output in your area on 151.265 / 100.0 R.
The various inputs are 159.435 / 100.0 (Pamlico Co), 159.435 / 131.8 (Beaufort Co), 159.435 / 151.4 (Onslow Co) and 159.435 / 173.8 (Greene Co).
Shortly after I sent my first post to this message, I caught the district 4 weather report via my local S.C. DNR repeater, which uses the same input frequency and tone as Pamlico site.
Jeff Multer
