Pocket25: A Digital Voice Decoder for Android
bobruzzo
W1AV
Cranston, Rhode Island
I plugged and unplugged the dongle a few times and the prompt finally came up to always open Pocket25. Think I'm good to go from here...
Guess I mustn't have tapped the save icon the first few times. Duh!
How do you adjust the gain and ppm in this? I cant find anywhere to do it. I got it running but garbled sparse audio. Gain might be too high and it says in the log ppm failing to set.
bobruzzo
W1AV
OK I found where to make those adjustments but still showing same error in log about failed to set offset tuning (-2) I dont know what to set this option to. In my sdr trunk program the ppm is set at -1.676. I tried that in DSDNEO but still same issue.
bobruzzo
W1AV
So -1.676 works in SDRT but not Pocket25 and DSD NEO? That's odd.
I have tried everything possible and no luck. I did set the gain to 20 and ppm to 0 and used extension otg cable to get dongle away from phone and while reception did clear up a little, I still get the ppm error.
noamlivne
When is another update coming out
Perhaps Sarah and DSD-NEO can cooperate.
DSD-NEO already has an Android app that can utilize (most of the) CLI switches and listen to P25 / NXDN / DMR (conventional and non-conventional, encrypted and non-encrypted) etc.:
arancormonk
DSD-neo | mbelib-neo
the engine is completely front-end agnostic now, which was not the case almost a year ago, so anyone can build off the current codebase and smack a UI on it. i'm pretty terrible at UI design, so i welcome any PRs for UI/UX improvements (or don't use it, doesn't matter to me either way :cool:).
