I sort of hi-jacked another thread talking about this so I thought it would be apporpriate to do a new thread.
I recently did the firmware update to my BC246T. After I was done it would not accept power from the wall-wart. I confirmed by using a meter that there was power and even tried another wall wart "just to be sure".
Although it had nothing to do with the firmware itself, I think that the process of how you get into and out of update mode caused my problem. At one point it seemed like it was just coincedence but upon reflection I believe that is not the case.
When you have finished uploading the update the update program pops up a screen that says "Turn off power and disconnect your scanner" or something to that effect. If you press the power button in the normal way to turn it off, nothing happens. So you need to pull the power plug. I foolishly pulled the plug out of the scanner instead of pulling the wall wart out of the wall. I will bet a truck-load of money that is what fried something inside the scanner. I should have known better expecially after recently installing an Xplornet dish and the instructions in there specifically tell you to unplug from the wall, NOT THE MODEM, to do a power cycle. You can get quite a spark at the plug when you pull it out.
Too bad the updater screen that pops up did not say something like that as a little reminder to not get hasty and take the time to stoop down and pull it out of the wall.
Oh well, live and learn. At least it still runs on batteries. I was using an external charger 90% of them time anyway while travelling.
