PPS Not Seeing Pager
radio3353
I am in Tab E, Program from Existing Profile. Pager is on and USB cable is plugged in (and connected because the pager starts charging.) But, my pager does not appear in the Programming Pager line. This started happening a few weeks ago. It was never a problem before that time. Anybody else ever have this problem and know what is causing it? Thanks.
(PPS is version V0.3.14.15.)
Note: This is happening with both my G4 and G5.
KB4SHP
My problem was caused by Norton my antivirus I disabled and it works just fine
IAmSixNine
Dallas, TX
I have had USB port go dumb on a desktop. Reboot fixed it.
Also try a different micro usb cable.
Also try to reboot your computer.
When you plug in your pager do you hear your computer make noises as its connecting to the device and setting up the drivers to make the proper connection? Charging indicates no data connection. When i hook mine up to my PC i get PC Connected on the screen.
RBMTS
That's a good point. Make sure you are using the USB cable that came with the G4/G5. Some mini USB connector cables are meant to only charge a device. The Unication cables have all of the proper connections for the data RX/TX comm lines.
radio3353
...Charging indicates no data connection...
Thank you. That sent me in the correct direction. I have too many cables in my life. I was plugging in the USB cable from the AC adapter, not my computer.:oops: My second dumb mistake today!
Thanks to everybody for sending suggestions.
IAmSixNine
Dallas, TX
Glad you were able to figure it out.
I learned that many years ago when phones started to take higher current charges and cable makers started to make cables for charging only aka no data, to handle higher current through put.
While its not happened to me on my G4 i have used the wrong cable on phones a few years back. So now anytime i have a failure with a device swapping usb ports and cables are my first go to, to fix the issues.
