PPS Question
nyscan
I know it has been touched upon in previous threads but I have not found a definitive answer. If you do not want a tone does it matter if you set the Alert Mode/Alert Tone setting to None/None or set it to Tone/None in the Group ID Setting? I know the Alert Mode setting in Zone and Channel Setting needs to be set to Tone in order not to mute the speaker but that doesn't seem to be the case in the Group ID Setting.
Dafe1er
Off in a far away place, far from u.......
Set it to none and all you will receive is audio.
nyscan
That does appear to be the case. However the Tone/None setting seems to produce the same result and seems to be recommended in previous threads. Is there absolutely no difference or does anyone know of any?
wmlovell
Aurora, OH
"Alert Mode" you will need to set to "Tone". ....Otherwise, your radio will be silent on that talkgroup.
"Alert Tone" you will need to set to "None" ...so it doesn't beep every time somebody talks.
Hope that helps
nyscan
That is true for the Zone and Channel Setting setting. Still get audio when none is set in the Group ID Setting.
N6ML
I'm fairly sure that either Alert Mode = None or Alert Tone = None (or both) on the Group ID setting (D4) will work to suppress the tone. What really matters is that Alert Mode must be Tone for the knob position (D5) if you want the audio to not be muted.
nyscan
Yes that seems to be the case, Just in light of previous threads specifying that the setting must be Tone/None I wanted to be sure that there is not any difference I may be overlooking. None/None actually makes more sense.
