Hello, all. I'm looking hard at buying an SDS100; many options to choose from exist that I never knew about until recently. Can anyone tell me, from practical experience, if getting a preprogrammed SD card with the radio purchase is worthwhile? If it is, why? What will I gain? Any information is appreciated.
As already mentioned by several others, the 'dealer programming', when you order online, is something you can easily do yourself, so save that additional cost.
Besides multiple threads here on RadioReference, as well as information in the
Wiki, there are a large number of "how to" videos on YouTube. Here's a few I pulled up with a quick search:
In addition, there is an "Easier to Read"
manual for your scanner online, as well as
another for the Sentinel software.
As
nosig has noted, you can download & install Sentinel before your scanner arrives. When you first install Sentinel, the database may be well out of date, by several years, so be sure & update it.
You might also request that your thread be moved to the regional forum for your state. Asking there, you may find someone relatively close to you that will share a file, both giving you a "jump start" in using the scanner, as well as an example of how someone else programs the scanner.
While. in the long term you may find that one or more Favorites lists that cover what you are interest in is the best way to go, you can at least start listening by updating the main database in Sentinel and scan using your location and range. Regardless of whether you use Favorites lists, or your location & range via the main database, be sure to enable the Service types for what you want to hear. When shipped, only the Dispatch service types are enabled for public safety agencies, i.e. Law Dispatch, Fire Dispatch, EMS Dispatch, and Multi Dispatch. You should also enable the
Tac &
Talk types for these (Fire Tac, Law Talk, for example, plus the same categories for the others).
Also, if you are interested in the paid upgrades that are available for DMR, NXDN, & ProVoice, do not pay the dealer to add them. They'll charge you $75 or more, whereas you can get them direct from Uniden for $50 each for NXDN & ProVoice, and $60 for DMR. ProVoice is pretty much a waste for almost everyone. That type system is no longer supported by the manufacturer. There's only a few active systems still using ProVoice. The others have migrated to a different type system (often P25), and just about all of the few still active systems will be making the move as well. I would advise that you do not purchase any upgrades until you've had your scanner long enough to make sure that there are no issues that might prompt you to return it to the dealer. Once you are comfortable with the scanner, and have verified that everything works as intended, only then would I purchase one or more of the upgrades, if you have found that certain agencies of interest to you use one of those system types.
