Priority scann on PD785(2)
ottosykora
Basel, Switzerland
I need to have a channel where a regular communication in talk around simplex takes place. At the same time I need to monitor repeater output on other channel.
I have set the TA channel as digital priority channel.
So far the priority channel seems to behave as it should, transmissions on it are heard with minimum interruption from the repeater channel.
But when I try to call via the repeater channel, the call is not registered unless I make 3 transmissions on the repeater.
This includes also the ALLCALL!
If I transmit on the repeater output in talk around mode, the call is registered (slightly delayed by prio scan) but it is registered fine.
ALLCALL on talk around (repeater output) captured the receiver almost immediately.
Any idea why the repeater has such big problem to reach the radios?
Pittsboro IN
Does a non scanning radio on the repeater channel brings it up the first time it's keyed?
Are you still scanning the simplex channel when you switch to the repeater channel?
Sounds like scan TX mode could be a problem if you are.
ottosykora
Basel, Switzerland
Yes, non scanning radio reacts imediately as expected.
Even when the scanning is a non priority, it reacts normal.
The scann takes:
1.prio simplex channel Freq1
2. nonprio repeater output at Freq2
3. nonprio simplex (same as repeater out in fact) on Fre2
The task is, while rather heavy communication takes place on the prio channel on F1, the stations should still be reachable on the Repeater Network on F2. As the repeater is mobile and can be on air or not, simplex channel (as repeater bypass) is used as well. Landing on the F2 simplex channel will make tx during the landing time in simplex, while receiving on repeater channel on F2 should make tx via repeater during landing time.
Note that when switching prio scann off, behaviour is ok, however it is desired that the F1 has priority.
