Pro-106/ARC500/New Christmas Toy
jerk
jerkville
Thanks for testing that out, and providing details. I can get Henryville & floyd just fine. I'll give it a try, and see how it goes. BTW, i've been playing around with your file and scan lists, and it works great. I also took your advice on separating conventional and talkgroups, and it has helped some.
Feel free to change the file to suit you. I use it when I travel to that area or Louisville, I also have a specific Louisville file.
The fed in Bank two are KY EMA and some other stuff.
The Mil-Air should get you some reception as well. Do a search here on Thunder and I have that file posted there along with some Thunder stuff. Or look at the April-May listings.
But make Henryville and Floyd primary (the first two) and if Jeff is what you want the most, enable Priority for the Disp 1 group, disp 2 is for events or big incidents.
But the Priority works well on this scanner, Clark Sheriff and EMS talk and talk and talk, and that probably blocks some of what you want to hear. I usually always temp lock-out CCSD because they talk so much.
I may get a chance to check out things today, problem is Jeff PD is very quiet in the morning.
