Hey Voices,
Thanks for the input. Normally I'd agree but I did some heavy checking before I posted. First, I'm an EE and second I've had years of experience both investigating and designing battery chargers. The first thing I checked was with a DVM on the main battery contacts without a battery in it but with AC plugged in. 0 volts as expected. I then carefully examined the contacts. I disagree on your saying that it takes a substantial amount of misalignment on the charge contact to hit the main battery contact. Actually it's about 1-2 mm. Mine has just a small shift to the right as you face it and does contact the main contact. Hardly noticeable.
As to your statement about current limiting on the charge circuit, you are absolutely correct. It is limited to about a maximum of 150- 175 ma. The output voltage of the charge is about 8.06 volts, unloaded. That current pushed by the max voltage available is more than enough to ultimately breakdown the batteries creating shorts in them. This causes heat which, unchecked, causes more breakdown and shorting. Ultimately, one battery starts absorbing the total current and voltage. Calculating power (P=IE), you begin dissipating roughly 1.5 watts inside the battery, primarily in heat. No place for it to go so it continues to build. The scanner itself has no smarts to decrease either voltage or current or to watch cell temperature. All important parameters in well designed chargers. Last important charger parameter is time limiting. When turned off, the scanner supplies charge current no matter what when it's plugged into the adapter.
Therefore, the only safety margin is to use the black holder but even it can fail and destroy the batteries and/or the scanner.
