skatertj
Hey, Im having an issue with my pro-106. It appears to be a interference issue of some sort but I dont know if it is truly interference or not. I have included a video of my issue to help everyone understand what my scanner is doing. Video---Radio issue - YouTube
My description of the issue would have to be a high pitch oscillating sound when receiving transmissions on Tulsa Site Details (Oklahoma Wireless Interoperability Network (OKWIN) Motorola). In the video, you will hear a high pitch noise. That is my scanner but im not sure why its doing it.
To help understand my problem here is a list of helpful information
-Scanner has been dropped in past on carpet only. Issue never occured directly after. No issues after drop.
-Site says its 2-Site Simulcast. I have programmed the TSYS Multi-Site to Roam and Stat- NO help.
-Using custom reband plan-did help after changing T Tables to custom.
-Issue occurs anywhere(In house or car) and with or without batteries. Happens with car and ac adapter.
-Not related to cell phone distance.
-Did appear to happen after programming with Win500 but am not positive.
-Occurs with or without backlight or led on or off
-Appears to only happen on Tulsa's site, not Coweta( BOTH on Okwin system)
-Does happen randomly and does happen with external OR internal speaker
-DSP and CPU are both up to date
If you can help me figure out this issue, that would be great! Any tips, please let me know. This is my second pro-106 that has done this. This scanner was a replacement for my first, which I had to return for this exact reason. My current scanner(one in video and new issue) just started this randomly and was fine since I first got it.
Also, Im not sure if this is normal either. The signal bar seems to flash slightly when scanning. I never noticed it before but have now. It doesnt flash when receiving only scanning and does for both tulsa and coweta sites.
If my scanner needs to be sent in for repairs, i will. It is still under warranty and needs a new screen anyway. It has a defect in the screen when viewing through polaroid sunglasses or when I'm in a dark room and the TV light hits it. Attachment shows defect!
Thanks for any help!!!
