bwigg
- Joined
- Jun 30, 2005
- Messages
- 79
I just bought a new PRO 651 and the battery charge circuit is not working. Of course it is non returnable due to the liquidation going on at Radio Shack.
I have the battery type set Nimh and it refuses to charge. I measured the current draw and it only draws 14ma when the battery pack is inserted with the yellow battery holder. It makes no difference if the charger is disabled or what battery type I choose. External power works normally and it does show a blinking icon that it is charging.
I measure 10 volts across the contacts with no battery pack inserted, but it drops to the battery terminal voltage when the pack is inserted. I opened the unit up and it appears as though the ground side of the charge circuit is controlled by a SMD NPN transistor. But without a good schematic I am lost.
