Pro-106 Programming Cable
rk911
Rich
Wheaton, IL
looking to buy a Pro-106 to compliment my Pro-197. is the programming cable i have for the 197 the same one used for the 106?
jassing
Shelton, WA
When using the cable, do you use the "pig tail" adapter?
The paper work shows that the pigtail is used for base/mobile scanners, and directly for handheld...
The driver appears when I plug in the cable; but no software will read the scanner...
any idea what I'm doing wrong?
thanks
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I'm going from memory here, but I believe you don't use the pigtail...best regards..Mike
jassing
Shelton, WA
Thanks Mike! I guess I was just worried about shorting something out--- that was it!
slimboxer
jamestrahan07@yahoo.com
pro 106
i have a pro 106 and never downloaded no programe on it that 2.0 are whatever ones they have,what will my scanner do more if i download it will i be able to sepeate locals from state pol air med. any help thanls
KC5EIB
Flower Mound, TX
Using WIN500 (Or any of the other programing software) makes it easier to manage the information in the different scanlists
jassing
Shelton, WA
I agree -- While I came from a scanner that you had no choice, you had to enter manually each frequency into each bank; I found the Pro197 about the same to manually program; but with better organizational powers.. (move from bank to bank, etc)
The cable makes it very nice (IF you have a windows system) -- and if you have a subscription to RR - it makes your life a LOT simplier/easier -- you'll spend more time listening.... I second win500. PSREdit was a very close 2nd choice.
HogDriver
Blackford Co. Indiana
Just something to throw out there. If you have a 197 and a 106, you can program the 106 from the computer then patch the 106 to the 197 and clone it. It makes it easier if you have a radio mounted in your vehicle.
HogDriver
BTW has anyone figured out how to print out your programming database from Win500 so one can have a hard-copy of what's in the radio? I have over 1600 objects in mine!
