PRo 106 question
Wahoos4Life
Rixeyville Va
When I am scanning with the 106,
It well stop on a station with almost full signal, or full signal
but it well be nothing but static, I've ben working with the squelch , but it will still stop on stations that have a full signal meeter, but just static coming out
what is going on here?
spooney
Indiana
Very sensitive front end reception on VHF freq's. Use ATT and see if it helps.
iMONITOR
Silent Key
S.E. Michigan
That's like saying my car has been acting weird, what's wrong?
What type of system, analog, digital, what band? Some encrypted systems will behave like you describe. We need more information to even begin to help.
Have_Teeth
Banned
The innards of the 28F640W18BD60
The scanner isn't a commercial radio. It doesn't have a "front end" per say. You'll need to knock down the signal strength of everything coming into the scanner, or you'll need to use some type of bandpass filter.
Sounds like you're in a very high-RF environment.
Also try a FM trap. They're like $5 from Radio Shack and can make a huge improvement. For $5 and a trip to RS, it's a quick and cheap fix if it works.
mancow
N.E. Kansas
Sure it has a "front end" just like any other receiver. The problem is that its very sensitive and not as narrowly filtered as a mono-band receiver.
