pro 106
chasdawg59
Texas
On my pro 106 i have it working with new rebanding with great sound the only problem after they talk it keeps going back to the same channel then scans then another channel show no sound does it all the time
chasdawg59
Texas
mot 800/900 mhz
Baytown pd texas i picked up them talking after they quit talking it scans the same channel with no sound then it scans another channel with a different tag with no sound now it quit all channels i was told we have to put a code in scanner to get working again
Rebanding is complete for the Hartman bridge. Control channel is 851.10000c , alternate control channel is 853.05000.
You just need to know if the scanner supports rebanding. If it does, then it will work on any 'rebanded' system in the US.
Talk group ID's have not changed.
16208 3f5 A Baytown PD 1 Ch. A1 Police 1 Primary Law Dispatch
16240 3f7 A Baytown PD 2 Ch. A2 Police 2 Secondary Law Tac
16272 3f9 A BaytownPDCID Ch. A3 Police Detectives Law Tac
16304 3fb A BaytownPDAdm Ch. A4 Police Administration Law Talk
hiegtx
Dallas, TX
mot 800/900 mhz
mot 800/900 mhz is not the information that tells what system you're trying to monitor.
However, you are apparently trying to monitor the analog version of TxWARN
Texas Wide Area Radio Network (TxWARN) Motorola Trunking System, Metro Houston area, Texas - Scanner Frequencies
That system rebanded near the end of last year. Your Pro-106 will handle a system that has undergone this process, but it does require the entry of a custom band plan. See the link provided to your question regarding
http://forums.radioreference.com/radio-shack-scanners/230280-reprogram-band-plan.html
This can be done either via software, or on the scanner itself. But it is necessary for your scanner to correctly track the system.
