cogswell1635
I purchased a used Pro-107/iScan scanner on Ebay but I am having issues. The CD the seller sent me was blank, no software. I downloaded the PSR-700 EZ Scan SD software because I'm told that works.
When I turn on the Pro-107, and go to "Browse Library", the screen says "Database files not found on SD Card.". If I take the SD card out and look at it on my computer, there are four folders: BTMP, CDAT, MTMP and STMP. Only the CDAT folder has anything in it.
If I start the EZ Scan software, and select SD Card/Copy library to SD card, a pop up opens saying "Select SD card", but my SD card isn't displayed in the drop down list.
I'm at a loss as to what I need to do to get this SD card properly programmed with the frequencies I need. Any help/suggestions would be greatly appreciated.
