Hello there,
Currently my scanner is having a problem streaming onto RR via the RadioReference edition of ScannerCast. The problem is that it will run and connect to RR but whenever a call comes in it changes the Scanner Connection status from "OK" to "Not Communicating With Scanner". It displays the same text in the Diagnostic Information section. The RR Connection is "SENDING OK"
Additional info:
Scanner is a pro-197 streaming a trunked system. It is connected via PC/IF cable.
Scannercast RR edition is set to GRE PSR-500/600, the tag format is TSYS or SLST Name + TGRP/CONV.
I am on W7 64.
Thanks in advance for your help and responses.
PS: Currently it is displaying "NOT COMMUNICATING WITH SCANNER" in the Scanner Connection field, every once in a while it will change to "OK" for about half a second but that it is. I have tried all the "standard" troubleshooting methods.
More info: I restarted the program and re-started broadcasting. For the first couple seconds it said it was "OK" and then it started changing between "OK" and not connecting, a couple seconds later it changed over to what it was doing before I restarted the program.
Additional info:
I am on W7 64.
