PRO 2096
dalan57
Sabina, Ohio
I have a new/used Pro 2096..have programmed many scanners...for some reason this one will not scan local freqs...I have other scanner that work fine..it seems to be programmed correctly..but nothing
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
A few suggestions were given to you in your thread below when you reported the same issue back in September. Is this the same Pro 2096?
dalan57
Sabina, Ohio
tvengr
Well Known Member
Baltimore County, MD
The PRO-96 and PRO-2096 both have a problem with frequency drift on 800 MHz. Frequency accuracy is critical for decoding P25 systems. You may need to adjust VR3 inside the PRO-2096 (VR4 in the PRO-96).
radioscan
Radio Sensei
Southern Ohio
