Pro -92 edacs program
w6dff
Reno, Nevada
Greetings. I have a pro-92 scanner from RS. I have it programmed for Washoe County in Nevada, which is on EDACs system. I am picking up a carrier "Beep,Beep, Beep" at the end of each transmission. Is there a way in my programming software to eliminate that annoying beep? It's quite annoying. I am currently using win92 computer programming software on a Lenovo computer running windows 11 home edition.
Quiet possibly may recommend another softer program would be helpful.
My direct email for reply: w6dff@yahoo.com
Any help would be greatly appreciated.
Thank you.
ka3aaa
middletown, pa.
that beep more than likely is part of the system in question and there is no switch in the scanner or software to turn if off so you will need to live with it.
gmclam
Fair Oaks, CA
Make sure you have every frequency of the site you're monitoring programmed. It's an EDACS system, which will have some specific number of frequencies per site. ALL of them must be programmed, and with their LCN (logical channel number).
