Pro-94 Trunking Programming Problem
ledaekim
Virgini
I am attempting to program a Pro-94 for trunking and am running into a problem, following the instructions, I have selected the trunk system type (e2-800), entered all the listed frequencies for the system... the instructions then say to press SRC to start searching the entered freqs for the data channel... but nothing happens, it just stays on the last entered frequency. I have re-read the instructions and tried reentering all the data, but, its the same end result. Am I missing something simple here?
JT2Fast4u
Hi ledaekim. I just finished programming my Pro-94 for trunking, & did everything just like you, except instead of pressing the "SRC" button, I pressed the "scan" button first & then the "SRC" button, & it worked out fine for me. Also, one other thing, since you didn't mention anything about it in your post, you did press the "E" key after each frequency you entered, right? Good luck, JT2Fast4u
ledaekim
Virgini
I will give that a try... One thing I had thought of was pressing the data key while entering in a freq that was listed as data, perhaps that may do something. If I recall correctly, pressing scan, even while in prog mode jumped it back to the start and started scanning all freqs, but I will see when I have it in front of me again.
